The cover for my Edwards 895 will NOT come off, no matter what. Are there some special tabs or screws or something I’m missing? ANy help would be appreciated.
There are two screws in the strobe housing that must be removed in order to slide the cover up and off.
Pop off the cover and remove those screws and it should come off just fine.
Yes, the capacitor is high voltage. If you are really worried, find the solder traces on the back for the capacitor and touch them together with a screwdriver (while it is OFF) to discharge all voltage. Also, the cap loses voltage over time. If it hasn’t been on for a while, you should be OK.
Just don’t touch it and you’ll be fine. It was made to come apart this way.
There’s a way to step 24VDC to 12VDC with a couple of resistors. You could also hook up the coil of a relay to the horn NAC and hook up a 12VDC power supply into the relay contacts. I wouldn’t recommend either of these methods, though.
This is the schematic Andrew drew to help Nathan power his 12VDC RSS. This was the resistor method I was talking about - you might find success with this.
Edit: Oops, forgot to attach it! :oops:
Edit again: They have to be 100-ohm, 1-watt resistors.
Perhaps you can use the panel’s alarm relay to power a 24VDC computer fan in the backbox the alarm/regulator assembly is in…
Nah, that’s a terrible idea. :lol:
