Mircom mix-m500 modules
Does anyone know the difference and compatability between a Mircom MIX-M500DM AND MIX-M500DMAP?
Please only comment if you have experience with these modules.
Thanks!
AP = advanced protocol.
Is this kind of like notifier clip/flashscan? Newer panels use AP?
Can you use non AP devices on a newer panel?
Thanks!
The AP (advanced protocol) series is a protocol which is faster and has more device compatibility on the loop. the MIX-M500DMAP can replace the MIX-M500DM as its identical except with the newer protocol. it is similar to notifier flashscan. the older devices run CLIP protocol. Newer panels use AP. you can use AP on a newer panel but make sure the protocol is on clip otherwise the devices wont work.
Okay, i think you mean you can use the non-AP devices on an AP panel if its running clip.
Thanks for your help. I appreciate it!
Yeah thats what I meant!
