New here…I have a question in regards to an analog module…versus…a control I/O module?
Are they the same thing? Or, are they different in terms of an actual device installed within the system.
Thanks very much people.
Yes, Simplex analog addressable modules are I/O modules. Is there a specific model that you’re unsure about?
Here’s a table of common names and translations for specific brands who do not use the common names.
[table][tr][/tr][tr][/tr][tr][/tr][tr][/tr][tr][/tr][tr][/tr][/table][td]Common Name[/td] | [td]Simplex[/td] | [td]Gamewell[/td] | [td]Siemens[/td] |
[td]Monitor Module[/td] | [td]Supervised IAM/Monitor ZAM[/td] | [td]Point Identification Device[/td] | [td]Input Module[/td] |
[td]Control Module[/td] | [td]Signal IAM/Signal ZAM[/td] | [td]Signal Control Element[/td] | [td]Control Point[/td] |
[td]Relay Module[/td] | [td]Relay IAM/Relay ZAM[/td] | [td]Relay Control Element[/td] | [td]Output Module[/td] |
[td]Zone Module[/td] | [td]IDC ZAM[/td] | [td]Conventional Zone Interface[/td] | [td]Zone Module[/td] |
[td]Isolator Module[/td] | [td]Communications Isolator[/td] | [td]Line Isolator[/td] | [td]Isolator Module[/td] |
