School Bell & PA Systems
Talk about anything in this section.
User avatar
Robert A
Dedicated Participant
Contact:
Mon May 26, 2014 7:35 pm
I can't believe I haven't posted in this before!
Elementary School:
Some Dukane system, since the FA system is EST. The bell was a 2-second sine wave that I cannot for the life of me remember the pitch. There are no master time clocks anywhere.
Middle School (6th Grade):
This school had an EST3 replace the old Simplex system, so the master time system is probably Simplex but the PA system is likely Dukane. The bell is a 2-second sine wave, and I do not remember the pitch. There are Simplex master time clocks all over the place.
Middle School (7th and 8th Grade):
This school had a Rauland system with an interesting bell setup. One minute before the tardy bell, there would be two .5 second chimes, then the bell (again, a 2-second sine wave of unknown pitch) would sound. This school has Rauland clocks
High School:
My current school has another Rauland system, without warning chimes. The pitch on the bell is a B concert. Bonus points if you can guess the pitch of this one in hertz! This school also has Rauland clocks.
Robert Aslin
If you need to contact me for any reason, you may email me at aslinrobert15(at)gmail.com.
User avatar
EdwardsFan
Fire Alarm Technician
YouTube Username: Mircomfan
Contact:
Tue May 27, 2014 1:51 am
Here are some pictures of my high schools PA/bell System. The first one that was installed, was in 1988, when my school converted into a full on high school (was a seminary, then an all boys school, then a co-ed day school). The system was a Telecor 2. This is when they replaced the old bell system, which I recently discovered it was an IBM system. I was on student council my last year, so I used the PA system daily since I did announcements, and played music. It had numerous problems with communication during announcements, and the motherboard even fried in December, 2012. It also had no volume control with the music, so sometimes the music was really soft, other times it was deafening. It was eventually replaced during March break with the Telecor XL. The bell system was fairly easy to program, and with both the systems, you could make your own bell tone, as well as being able to program 4 bell schedules with 64 events each. Here is the old system first:
The first picture was the old control console that was in the announcement room. The second picture is the new refurbished one that was put in after the system fried. The most annoying thing about these was doing the announcements with them. You had to hold down the 'push to talk' button to keep the mic on, it didn't latch in.
This was the other control console that was located in the office. This one was used mainly by the secretaries to make announcements and page rooms during school. This one was used by picking up the phone and using the page feature, which it latched in.
The PA system in the announcement room. There were some features on the unit itself (which weren't in use by then) such as the FM/AM radio, and the tape player. You can also see a key at the bottom, that was a key used to program the systems time functions. Now the new system:
This was the new system installed March 2013. I forgot to take a pic of the new unit, but there is the new console, paging microphone, and the new CD player. The console is unlike the old one, pretty much the same features, but one exception. This one latches in, as well as the new microphone with it. I don't have a picture of the one in the office because it is the same.
Finally, the old systems final resting place was in the storage shed that was in the back of the school. Here are also some videos of both systems at work:
Old Telecor 2 system, New Telecor XL system (manual bell), and The new system with the automatic bell schedule.
LocalAlarm74
New Participant
New Participant
Mon Apr 23, 2018 7:17 pm
Elementary School: Simplex Time Recorder, with three toggle switches and a time clock system. Each classroom and the hallways had a small electric bell, I’m guessing 6” across. The timer is mechanical rather than digital. The bells rang on the designated time cycle, but could be overridden by flipping the switch down to activate it at any time. I remember getting to ring the tornado drill signal (repeated bell rings)with it. I bought an old system that I’m working on wiring up.
Middle/High School: Tones on intercoms, but I don’t know what system. The middle school intercoms looked like they were original to the building, but the high school system had been replaced at some point.
User avatar
Retired STR-SG
Moderator
Moderator
Contact:
Mon Apr 23, 2018 8:26 pm
The three switch device is a Simplex R83 program machine. It runs on a synchronous motor mechanism that advances each minute. It has three bead boxes, one for each circuit. Each bead chain has 1440 beads, one for each minute. Bells are programmed to ring by adding a larger bead to that minute of the chain to close a contact.
LocalAlarm74
New Participant
New Participant
Mon Apr 23, 2018 9:25 pm
That's exactly the one! Attempting to get mine running - with a couple of bells - will be a summer project.
User avatar
EdwardsFan
Contact:
Thu May 31, 2018 11:58 pm
I've seen these installed in some elementary schools. I've been dying to get my hands on an Edwards/Simplex time controller.
Gentex SPK4
Casual Participant
Casual Participant
Thu Aug 09, 2018 4:53 pm
Reposting mine:
Edgewater Public Elementary (1998-2003; Pre-K, K-1)
PA System
Older Rauland Telecenter from late 1980s
Speakers, Call-in Switches
  • SPECO, Rauland, and Bogen baffle speakers throughout the main building, the cafeteria had ceiling mounted Rauland speakers
  • Buildings 6-9 have ceiling mounted Rauland ACC speakers
  • Outside there were old Rauland or Executone baffle speakers
  • The whole school used Rauland call-in switches
Bell
1250hz tone over the intercom for 5-seconds. There are the remains of an older bell system (notably the motors for old Faraday vibrating bells, but there is also a 4-inch bell in the cafetorium!)
Indian River Elementary (1999; Pre-K)
PA System
Dukane MCS
Speakers, Call-in Switches, Clocks
  • Inside, there were Dukane speakers throughout (ones in the classrooms were wall-mounted).
  • Outside had Dukane Baffle speakers
  • Classrooms also had call-in switches
  • The school also had a clock system since the campus had Digital clocks throughout the campus (I remember my pre-K classroom having one)
Bell
850 hz chime tone over intercom
Spruce Creek Elementary (2003-2007; 2-5)
PA System
  • SPECO, Rauland, and Bogen baffle speakers throughout the campus, the cafeteria had ceiling mounted Rauland speakers
  • Buildings 10 and 12 have ceiling mounted Rauland ACC speakers
Bell
1250hz tone over the intercom for 5-seconds. Just like Edgewater, there are the remains of the old bell system (i.e. motors of old bells, and even a few 10 inch bells outside)
Creekside Middle School (2007-2010; 6-8)
PA System
Rauland Telecenter 21
  • Inside there are ceiling mounted Rauland ACC speakers
  • The gym has megaphone speakers
  • All classrooms have Rauland Call-in Switches
Bell
500hz chime tone over intercom
Spruce Creek High School (2010-2014; 9-12)
PA System
Rauland Telecenter ICS
  • Classrooms, media center, and O-Wing have ceiling mounted Rauland ACC speakers
  • Hallways have wall-mounted Rauland ACC speakers
  • Outside, and in the cafeteria, auditorium, and gym there are Rauland megaphone speakers
  • Classrooms have Rauland call-in switches
Bell
  • Main bell is a 515hz chime over the intercom, warning bell is a 825hz chime over the intercom. Sometimes there would be a 1150hz chime tone. Outside there are old 10 inch bells that are painted over.
  • Misc Notes: This system also has the capability to broadcast music over the intercom (but this has only been sodelmy used in my freshman and sophomore years), but has the capability to broadcast live audio from the TV production facility
User avatar
RSSAlarms
Casual Participant
Casual Participant
YouTube Username: RSS alarms
Contact:
Thu Nov 01, 2018 1:03 am
My primary school had an old PA system from 2001 when the school was built. I have no idea what the manufacturer of the PA system was, but I want to know if anyone can help identify it. The paging tone is a 1080hz tone, and the pa phone itself is white, does anyone know what it is? Also, the PA system was removed in 2016.
User avatar
Retired STR-SG
Moderator
Moderator
Contact:
Thu Nov 01, 2018 9:44 am
I found the tone list from a Simplex 5120 system. Do any seem familiar?
A white phone could be used by any supplier. The phones we used were white and from a large telephone supplier.
User avatar
RSSAlarms
Casual Participant
Casual Participant
Contact:
Thu Nov 01, 2018 1:18 pm
I don’t think it’s a simplex PA, all the basic functions were done through the phone itself. It could be a Bogen, Rauland-Borg or a Dukane PA. I guess I’ll never know, it’s been many years since I heard the paging tone, but I’m confident the tone is around a 1080hz square paging tone.
User avatar
RSSAlarms
Casual Participant
Casual Participant
Contact:
Thu Nov 01, 2018 8:14 pm
Also I forgot to mention that the school clocks are simplex, and also what do the chime tones sound like as seen on the tone chart?
User avatar
Simplex 4051
Contact:
Sun Dec 16, 2018 10:09 pm
Since my elementary school was renovated, I'm sure that they have a new PA system. I wonder what it is? And I also wonder what the old one was.
User avatar
Jack Boorsma
New Participant
New Participant
YouTube Username: System Fire 2.0
Instagram: systemfire2.0
Contact:
Tue Dec 25, 2018 10:37 pm
Well, My High School has a super high tech interesting bell system. It was installed in 2015 and it is a CareHawk CH1000. We use more than one bell tone. Since our high school has 2 buildings, there are students who need to transfer during the school day. So, a soft little warning chime will ring to indicate they need to get on the bus. We also have a 1 minute warning Bell, which is a loud “Church Gong” tone. Our main bell is the normal CareHawk Bell. Our all call tone is a 4 notes descending down tone. Want to hear these tones? Here’s a link to my google drive folder that contains a whole bunch of tones that I have collected:
https://drive.google.com/drive/folders/ ... Q-jCMzhuik
User avatar
Simplex 4051
Contact:
Sat Jan 12, 2019 10:07 pm
Those tones for your school certainly do sound very interesting and incredibly neat! I like how they are set up!
User avatar
DownsLife+Safety
Casual Participant
Casual Participant
YouTube Username: DownsLife&Safety
Wed Feb 06, 2019 7:13 pm
Is there a list of all possible Rauland Telecenter ICS tones you can choose? I'm talking about the ones where you can dial #3[tone]* and it plays that tone selected over the intercom.
DownsLife&Safety ~ Inspiring to live safer lives
Find my YouTube Channel Here!
Also a noob at fire alarm systems. :P
