Minecraft Fire alarm system.
The actual functionality of the panels was made by accident, but this is the conventional Minecraft fire alarm system i made.
This is the system. It contains 6 audible appliances, 2 “panels”, 3 fully working single action pull stations, and 1 “annunciator”.
This is one of the “panels”. It functions very similarly to an Alertek 5001 panel, where it relays a signal out to the alarms.
These are the alarms. They have a similar appearance to a Simplex 4050 w/ a 4050-80.
these are the pulls. Once pulled, they send out the signal first, but then the piston will quickly cut it off, creating a pause in the coding, and preventing it from continuously letting out a signal. These function like coded pulls, but the panel keeps the signal in circuit, and the pull isn’t constantly letting out a signal.
This is the system is alarm! To silence and reset, you would flick the top switch to jam the signal so the alarms stop, then flick it again to stop any constant flow of signal when resetting, then break the 2 top wires at the top of the panels, then wait a few seconds, then replace, and the system should be reset. Remember to reset the pull too!
Thanks for viewing! :mrgreen:
