My latest alarm tests
I did some tests of some of the alarms that I’ve had in my collection.
Gentex GXS
http://www.youtube.com/watch?v=a4u8kQtgXeE
Wheelock 7002T
http://www.youtube.com/watch?v=Ro3WzAm7uI0
Gentex GMS
http://www.youtube.com/watch?v=FjAZjBwpozM
Simplex 4901-9822
http://www.youtube.com/watch?v=3Mj5BvrDzSE
I will be uploading more alarm test videos in the near future.
Even more tests…
Wheelock 34T (it’s actually a Wheelock 36T on the label, but it is not much different from a 34T; see video description) - This one tends to act a bit weird with the pitch.
http://www.youtube.com/watch?v=buys8aKdWEw
Simplex 2901-9838
http://www.youtube.com/watch?v=3YVbc-AMY48
Edwards Integrity Horn/Strobe (757-7A-T; Enhanced) - I test it first on continuous because all the Intergities that I’ve heard going off in an actual installation were in Code-3.
http://www.youtube.com/watch?v=-a_dIIXY2r0
Wheelock MT-24-LSM - This is actually my newer one with a working strobe (the strobe on my other one broke due to not taking good care of it). I only tested three out of the eight tones: Code-3 Horn, March Time Horn, and Slow Whoop.
http://www.youtube.com/watch?v=xITC1ADB9Tw
Simplex 4903-9236
Horn/Strobe test
Strobe Only Test - I also took my TrueAlert horn/strobe (which I will eventually get to test; see more info in the video) and put it near the strobe just for kicks…
Simplex 4903-9219 - Unfortunately, the strobe stopped working (not due to it being powered by FWR voltage, but probably for not taking good care of it).
http://www.youtube.com/watch?v=x44UpTfqrNY - Also, at the end of the video, I explain (with proof) that I have both versions.
Gentex Commander3 Horn/Strobe - I only tested five out of the seven tones of this alarm
http://www.youtube.com/watch?v=gKjo6n0Rs5A
System Sensor MASS2415ADA
Hi-Lo (800/1000 Alternating) + Surprise
http://www.youtube.com/watch?v=InqPvasAV3k - I test six tones of this alarm since Hi-Lo was posted in the video linked above, and 800Hz was done in Mini Test 2.
Siemens U-MMT-MCS
http://www.youtube.com/watch?v=WxaWmr1kdXQ - Part 1; Part 2 will be coming, read the video description as to why I’m making two parts
http://www.youtube.com/watch?v=YjqwdORvcgw - Just a test of the strobe this time
EST Genesis Remote Strobe
http://www.youtube.com/watch?v=9k0ABctx3t0
EST Genesis RS + SpectrAlert Classic RS
http://www.youtube.com/watch?v=OodoPEyRNU4
Siemens U-MMT
Part 2 - http://www.youtube.com/watch?v=Vql7HKy_Ks0
Gentex Commander3
In 2400Hz Continuous and Chime Continuous/Pulse - http://www.youtube.com/watch?v=UyMaUo9ViIM
EST Genesis Horn/Strobe
http://www.youtube.com/watch?v=E8Nl12GUy30
Simplex 4903-9219
http://www.youtube.com/watch?v=0XQ82ztBqFY - This is take #2, but this is with a different -9219.
Wheelock MT-24-LSM
http://www.youtube.com/watch?v=Z-Irp1FXwHI - I do (yet another) test of my Wheelock MT-24-LSM horn/strobe, but the reason why I made this video is because all my other videos demonstrating all the tones of the MT did not have flashing strobe lights going off (Mini Test 5 does not count).
http://www.youtube.com/watch?v=KBc8t_PLUeQ - Another test of my EST Genesis Horn/Strobe. Not only that, but I also walk around my entire house to see how loud it is in other areas of the house.
I haven’t posted anything for at least a month, but I just recently posted a bunch of fire alarm videos on YouTube.
Please note that all videos have a disclaimer that runs for at least 20 seconds, so feel free to skip over the disclaimer.
Strobe-Only Tests
If you see a black rectangle, that’s because I had to edit out a pile of yearbooks that mentioned my school’s name and the town that I live in, due to me not being very careful where I was pointing the camera.
http://www.youtube.com/watch?v=FVsxTTFi2V4
Another test of my SpectrAlert Classic remote strobe, but running on full power (as opposed to just a 9v battery) from my power supply, set to 30cd, along with my Fire-Lite BG-12L.
http://www.youtube.com/watch?v=dxq38S67yqU
Another test of my Gentex GXS remote strobe, along with my Notifier NBG-10L
http://www.youtube.com/watch?v=f7pzpisijro
Another strobe-only test of my Integrity Horn/Strobe, along with my newer 270-SPO
http://www.youtube.com/watch?v=GzgCiY9G3mg
Another test of my EST Remote Strobe, set to 30cd, same pull as in the previous video.
Mini-Tests
http://www.youtube.com/watch?v=E9KD_PpUfWk
Mini Test 6; I did a similar setup to what my high school has (when it was initially installed in the 1980s); more info is in the description
http://www.youtube.com/watch?v=lV9OfcX98eg
Mini Test 7; A test of my Simplex 4903-9219 horn/strobe along with my 2099-9754 T-Bar
http://www.youtube.com/watch?v=3Z3dPMiQ4Tk
Mini Test 8; Same thing as Mini Test 7 except I’ve swapped out the -9219 for the -9236.
Once again, feel free to skip over the disclaimer in these videos.
Mini Test 8.5
http://www.youtube.com/watch?v=pyQu0SRNfHI
The reason I call it that was because it’s almost the same thing as Mini Test 8, except without a strobe.
I was initially going to do this test right after Mini Test 8, but it had the -9838 horn behind the shell at the time, and I had trouble trying to unscrew it from the shell (problem has since been solved).
Mini Test 9
http://www.youtube.com/watch?v=FfJsnjfgPWY
Mini Test 10
http://www.youtube.com/watch?v=AJzH1C444mc
Mini Test 11
http://www.youtube.com/watch?v=xMbeqXtX0h8
Mini Test 12
http://www.youtube.com/watch?v=KgtNnVwMNyM
Wheelock MT-24-LSM Strobe Test
http://www.youtube.com/watch?v=ZLO1uFHOKzY
Simplex 4903-9236 Strobe Test
http://www.youtube.com/watch?v=MJZhbkImcdA
A test of one of my alarms that recently arrived in the mail: the Federal Signal iStrobe.
The next two tests consist of two different strobe plates (with just their respective strobes going off).
Wheelock RSSP (with my Wheelock MT horn attached)
Simplex 4903-9101 (with my 2901-9838 horn attached, since they were packaged together when they arrived in the mail)
Mini Test 13, featuring the Edwards Integrity and the 270-SPO
There is more to come, so stay tuned.
Mini Test 14
Mini Test 15
Mini Test 16
A test of my Simplex 4901-9805 Horn
Another fire alarm mod that I did: swapping out the shell from the -9805 and putting the -9838 cover
If you think that I’ve gotten the model number wrong, then click here.
Mini Test 17
Mini Test 18
A test of one of the rarest alarms ever collected: my Simplex 4903 light plate.
Some of you may believe that it’s a 4903-9001 (myself included), however, from what I can gather from the label on the light plate (which I’ll post a pic of soon) has led me into question.
My 34T wired directly into my RSSP
https://www.youtube.com/watch?v=HjdSgjxNNyA - Please read the description
My Simplex 2901-9838 (different from -9838 that I’ve had for years) on my 4903 Light Plate
Same as before, but swapped out the -9838 for the 34T
Mini Test 20
Simplex 4903-9236 Strobe Test 3
Haven’t posted in long time, but I only have two videos to post for now.
A test of my Edwards Integrity horn/strobe (with only the strobe hooked up) along with my EST Genesis remote strobe.
Another test of my 4903 light plate along with my newly acquired 4251-20 T-Bar.
I know it’s been a long time since I’ve last posted alarm tests here, but here they are:
Mini Test 27
Mini Test 28
Mini Test 29
Simplex 4903-9219 and Wheelock 7002T Test
(I know this kind of setup has been done to death many times)
Simplex 4903-9219 and EST Genesis Test
I still have more videos that I need to post, though.
Here are the other mini tests:
Mini Test 30
This is a 3-part test (not just because this is “Mini Test 30” as that I didn’t know what mini
test number it was at the time of recording)
Mini Test 31
Mini Test 32
Mini Test 33
Mini Test 34
