System Tests | kcin556
This is where users can post any videos, recordings, or photos they have made that is related to fire alarms,
Forum rules
You are only allowed to post YOUR videos here. Please refrain from posting others videos.
User avatar
kcin556
Administrator
Administrator
YouTube Username: kcin556
Contact:
Mon Feb 16, 2015 5:52 pm
I've had a System Test series for a while but the videos used to be junk. Now that over the past year I have gained the ability to create decent videos, I'll post them here! :D
My current System Test series is from System Test 8 and onward, the older ones focused solely on my AutoPulse system when I was younger and hadn't built the current one yet, although both Systems are tied together as of now.
Here is my most current System Test video, released today. Enjoy!
kcin556 on YouTube wrote:First System Test with my new DMP XR-500 Fire/security panel! The panel only monitors the equipment, including the SXL-EX, AutoPulse 2000, DualTec motion sensor, and the POPIT modules, on the board and cannot activate anything other than its keypad. The keypad lights up in red during an alarm condition, which is present throughout the video due to the no battery condition on both of the fire panels. Although it is branded DMP, the 923-MCW-R is being activated from the normal SXL-EX fire panel and not the DMP XR-500.
Nick - Administrator
kcin556 on YouTube
User avatar
firealarmveteran15
Serious Participant
Serious Participant
Contact:
Mon Feb 16, 2015 10:25 pm
You would need to enable embedding on your video(s) in order for it to play here if that's what you intend to do.
User avatar
kcin556
Administrator
Administrator
Contact:
Mon Feb 16, 2015 10:33 pm
frankalarms39 wrote:You would need to enable embedding on your video(s) in order for it to play here if that's what you intend to do.
Oops! I have embedding disabled by default and didn't notice any problems since I was logged into my account and it allowed it to play for me. Thanks!
kcin556 on YouTube
User avatar
kcin556
Administrator
Administrator
Contact:
Sun May 03, 2015 9:50 am
Here's System Test 13, featuring a new Square D QO breaker box for the AC power wiring!
From the Description:
All the panels are now tied onto one power feed. Signals are a System Sensor MA12/24L set on 800Hz continuous, and a Notifier NWS-24 strobe. Special thanks to "Retired STR-SG" on TFP for helping me troubleshoot a small problem with this strobe and get it connected!
Initiating devices are a Honeywell S464A, an Edwards 270-SPO (which is unfortunately too close to the DMP XR-500 to unlock with a regular screwdriver) and the usual unappreciated Chemetronics 604 heat detector.
Not really sure whats going on with the audio in the beginning but oh well.
kcin556 on YouTube
User avatar
kcin556
Administrator
Administrator
Contact:
Mon Sep 14, 2015 8:15 pm
Here's my newest test, System Test 14.
Video Description:
Doing something a little different this time by activating the Ansul AutoPulse 2000 system as well as the usual main system.
Initiating devices on the SXL-EX are a Simplex 2099-9754 "T-Bar" and a Simplex 2099-9768 "Chevron" pull station, as well as the usual Chemetronics 604 heat detector. Notification appliance is a Simplex 4903-9426 TrueAlert.
Initiating Devices on the Ansul 2000 are two SIF-24 smokes, and a Jackson Associates MPS-1. Notification appliances are a Federal Signal 450D+Fiquench 20-048 and an Ansul 57549 Bell.
The DMP XR-500 also activates as usual in response to the monitoring contacts on the other panels,
Thanks for watching!
kcin556 on YouTube
User avatar
kcin556
Administrator
Administrator
Contact:
Sun Dec 06, 2015 7:40 pm
System Test 15 is here, featuring a new keypad and some vintage, and very difficult to activate :wink: , pull stations!
I've got something new that wasn't installed when I made this test, so hopefully I'll be able to share it with those interested sometime soon.
kcin556 on YouTube
User avatar
kcin556
Administrator
Administrator
Contact:
Thu Jan 14, 2016 8:48 pm
System Test 16, featuring my new fire sprinkler riser setup!
kcin556 on YouTube
User avatar
kcin556
Administrator
Administrator
Contact:
Sun Apr 10, 2016 9:25 pm
System Test 17 - from a while back
System Test 18
kcin556 on YouTube
User avatar
kcin556
Administrator
Administrator
Contact:
Fri May 27, 2016 7:29 pm
System Test 19. Enjoy!
kcin556 on YouTube
User avatar
kcin556
Administrator
Administrator
Contact:
Wed Jun 22, 2016 8:31 pm
Here's System Test 20!
kcin556 on YouTube
User avatar
kcin556
Administrator
Administrator
Contact:
Sat Aug 06, 2016 9:31 pm
System Test 21, featuring old Honeywell equipment by request!
I also give a brief demonstration of my DMP XR500's features at the end of the video, also by request. Check it out!
kcin556 on YouTube
User avatar
kcin556
Administrator
Administrator
Contact:
Sun Sep 11, 2016 8:42 pm
System Test 22 is now available! This video really shows the effectiveness of Mechanical horns over Electronic horns.
Enjoy!
kcin556 on YouTube
User avatar
kcin556
Administrator
Administrator
Contact:
Wed Oct 12, 2016 6:31 pm
System Test 23 is out, featuring several devices I have not had the opportunity to use in over 4 years!
kcin556 on YouTube
User avatar
kcin556
Administrator
Administrator
Contact:
Sun Nov 13, 2016 8:04 pm
Today I filmed System Test 24... and experienced somewhat of an equipment failure on camera when I tired to activate the waterflow switch near the end of the video. Here it is below:
As a side note, those two POPIT modules at the bottom of the enclosure were not installed like that. The paint on that panel is so slippery that double-stick tape just slides down over time. About a year ago they were mounted straight and 2 inches higher!
Thanks for taking a look!
kcin556 on YouTube
User avatar
Simplex 4051
Dedicated Participant
Contact:
Wed Nov 16, 2016 6:11 pm
Wonderful system set-up that you had there! I'm wondering if you thought about expanding the system or putting devices in hallways?
