Here’s my Mini-System-Test Series I have like 20 other tests but haven’t uploaded them and probably never will. Since im so lazy!
Check out my Fire Alarm Channel HERE:https://www.youtube.com/channel/UC_uca8nj9xep37yQSiGyyTg
[YouTube]21s[/YouTube]
Looks good so far! Did that GXS come with a mounting plate?
No, i don’t believe so. So thats why its so hard to mount?! Also, I have made a demonstration pole. You will see what I mean by pole instead of board soon!
If the screw holes line up you might be able to fashion an improvised mounting plate with a single gang to 4" adapter ring. Just mount the ring sideways on your 4" box.
For some reason it isn’t letting me play the video. Did you remove it for some reason?
Im so sorry! I put 21s because I thought that was the video ID but that was because it saved were i was at, I was at 21 seconds of the video! Ill fix it!
Here is the fixed version since I dont know how to edit the original post.
[YouTube]oeUATXRw9R0[/YouTube]
Nice job on this video! I hope to see more from you soon!
