Fire Protection Jeopardy
We’ve had question-and-answer quiz topics on this forum before, but I don’t think anyone’s ever flipped it around! So now, instead of answering the question, you’ll have to ask the right question that goes with the answer!
And if you’ve got any ideas, go ahead and ask (or rather, answer!) them here. So…
This model of representing fire includes the elements of heat, fuel, oxygen, and a chemical chain reaction.
[quote=randomperson post_id=87666 time=1600267602 user_id=3878]
Fire triangle
Incorrect! Also, needs to be in the form of a question :mrgreen:
This type of signaling is intended for response by trained building personnel, rather than the general public, and is exempt from certain notification requirements.
[quote="Simplex 2903-9101" post_id=87674 time=1600287159 user_id=3578]
What is private mode?
Ding ding! You are correct.
This device is used in sprinkler systems to prevent momentary surges in water pressure from causing false alarms.
[quote="Simplex 2903-9101" post_id=87676 time=1600359251 user_id=3578]
Tamper Switch?
I’m sorry. That’s incorrect. “What is a retard(ing) chamber?”
This NFPA code is also known as “Standard for the Installation of Sprinkler Systems in Low-Rise Residential Occupancies”.
What is NFPA 13R?
[quote="Jaxon Lewis" post_id=87701 time=1600824807 user_id=6269]
What is NFPA 13R?
Correct!
The four main types of automatic sprinkler system are wet, dry, deluge, and ______.
[quote="Robert A" post_id=87710 time=1600889710 user_id=2817]
What is pre-action?
[quote="Robert A" post_id=87665 time=1600264549 user_id=2817]
What is the fire tetrahedron?
What is a pre-action system?
Correct!
This chemical compound is also known as type ABC fire extinguisher agent.
What is Monoammonium Phosphate?
[quote=RSSAlarms post_id=87724 time=1601058261 user_id=4672]
Correct!
This factor, referred to by a single letter, is a way to express the relationship between flow rate and pressure with the unit of gpm/sqrt(psi).
[quote="Robert A" post_id=87725 time=1601067650 user_id=2817] [quote=RSSAlarms post_id=87724 time=1601058261 user_id=4672]
Correct!
What is M?
This panel is infamous for its CPU faults. It is the previous generation of mid-size panels from a company that has changed hands twice during the duration of this panel’s manufacturing.
[quote=DownsLife+Safety post_id=87734 time=1601348151 user_id=4181]
What is M?
Incorrect. “What is K?” is the correct response.
[quote="YYC Fire Alarms" post_id=87800 time=1603312302 user_id=4467]
What is EST3?
[quote=RSSAlarms post_id=87804 time=1603345783 user_id=4672] [quote="YYC Fire Alarms" post_id=87800 time=1603312302 user_id=4467]
What is EST3?
Close, but incorrect!
