Make Up a System (2.0)
Gentex SPK4
Casual Participant
Casual Participant
Sun Feb 25, 2018 12:08 am
Farley Elementary School, built in 1959, originally had an Edwards 1225 fire alarm system. Signals were mostly Edwards 364 horns. Each hallway had 3 horns, the auditorium had two horns, the cafeteria had one horn, and the library had one horn. Each horn had an Edwards 270-SPO pull station underneath it. Heat sensors were also installed throughout the school. Signal coding was 4-4. For class change bells, they used 6 inch Standard Electric Time bells. These bells were installed throughout the school. Outside they used 10 inch Standard Electric Time Bells. The master clock panel was also from Standard Electric Time.
In 1972, the roof in the auditorium collapsed. When it was renovated, the two 364 horns were replaced with Simplex 4050 horns with projectors. Two Simplex 4521-20s also replaced the 270-SPOs, and two Edwards 10 inch bells replaced the SET bells in the auditorium.
In 1976, a 364 in the library failed to sound and was replaced with a Edwards 871 Adaptahorn.
In 1986, the school was added onto. A Simplex 4002 replaced the Edwards 1225. Signals in the new wing are Simplex 2901-9838 horns on 2903 strobe plates, pulls in the new wing are Simplex 4521-30s, and Simplex Wiffleball smokes are installed throughout. Signal Coding is now continuous. The master clock, bell, and intercom systems were replaced during this time. The school bell is now a tone over the intercom. The master clock panel is a Simplex 2350.
In 1992, the whole school was remodeled except for the addition. The new signals replacing the Edwards 364 horns are Simplex 2901-9846 horns on 4903-9105 strobe plates, with 4904 strobes in the restrooms. Classrooms get System Sensor PA400R horns, and the auditorium gains Simplex 2902-9711 speakers on 4903-9105 strobe plates. Pulls are now Simplex 2099s, and Simplex 2908 series smokes replace the existing Edwards heat sensors. A Simplex 4003 is tied into the 4002 to serve the auditorium. Everything else stayed the same.
In 1995, classrooms in the new wing gained System Sensor PA400R Horns.
In 1998, a 2901-9846+4903 died and was replaced with a Wheelock MT-WM Horn/Strobe set to continuous horn.
In 2002, a Simplex 2901-9838 failed to sound and was replaced with a Wheelock AS horn/strobe, and the light plate was disconnected.
In 2005, two 2901-9846+4903s were replaced with Simplex TrueAlert Horn/Strobes.
In 2007, a couple of System Sensor PA400R horns died and were replaced with Wheelock NS horn/strobes (set to code-3).
In 2008, the 4002 died and was replaced with a Simplex 4100U INFOALARM. Everything stayed the same.
In 2010, another new addition was built. Signals are Simplex TrueAlert Horn/Strobes and Strobes, along with Simplex 4099 pulls and Simplex TrueAlarm smokes.
Over the course of 2011, 2012, and 2013, a number of Wiffleball Smokes were found inoperative and were replaced with TrueAlarms.
In 2014, a 2902 speaker failed to sound and was replaced with a Wheelock E50 Speaker.
User avatar
Simplex 4051
Dedicated Participant
Contact:
Sun Feb 25, 2018 1:56 am
This high school fits about 800 students.
The school has a mixture of old and new Gentex SHG horn/strobes so there are a lot of different pitches and where you are in the school determines what pitch you will hear
Out of ten workforce development rooms, two of them have Federal Signal 450D horns with VALS strobes attached. One computer lab and the chorus classroom also have these horns.
Another workforce development room as well as the exception children classroom have Edwards 881 Adaptahorns on 891D light plates
The wrestling room has a Fire Lite 450 horn behind a Space Age Electronics AV32 light plate
One science classroom and one other workforce development classroom have Wheelock NS horn/strobes
Then two wings in the school that were damaged by a tornado were renovated and received Gentex GOS horn/strobes set to 2400 Hz temporal as well as a resource room and the health room getting the alarm
User avatar
idontwannaknow
Serious Participant
Serious Participant
Thu Mar 01, 2018 10:08 pm
Frederick Elementary School was finished in 1996. It features a gym, a lunchroom, two music and art rooms, a library, a drama room, and a main office. There are other random offices scattered around the school too. The first system was a Simplex 4100 system, with Simplex 4903-9238 horn/strobes in the hallways. Three of these are in the gym, two of them in the lunchroom (one in the kitchen), and one on each side of the library. The music and art rooms, and the drama room each only have one -9238 in them. Pulls are Simplex 4099-9001s and detectors are TrueAlarms.
In 2000, Simplex 4901-9858 mini-horns were placed in each classroom and each office. A Simplex QuickAlert was installed beside the main door and one in the entrance of the main office. Simplex QuickAlert strobes were mounted in the bathrooms, as well the nurse office.
In 2005, a computer lab was built, featuring a Simplex TrueAlert horn/strobe. There is one TrueAlarm on the ceiling.
In 2008, another section was built for more classrooms. Simplex TrueAlert horn/strobes are installed in the hallways, while ceiling mounted TrueAlerts are installed in the classrooms. Smokes are TrueAlarm and pulls are 4099-9003. Everything is now Code-3.
In 2015, old classrooms designed for health learning had their walls knocked down to give for a larger room— three of these exist, speaking of three , these newly renovated classrooms are now three normal classrooms long. Two exit doors are put on both sides of the wall leading to the hallways. A Simplex ceiling mount horn/strobe is mounted on one side of the health room, while a strobe is put on the other side. A trueAlarm is in the middle of these rooms.
The system remains, yeah small upgrades IK.
draw
User avatar
Simplex 4051
Contact:
Fri Mar 02, 2018 2:00 am
This elementary school holds 914 students and has a system that is set up in this way.
In most areas not listed, even the bathrooms, there are Siemens U-HNH electromechanical horn/strobes
In the largest resource classroom, there is a Simplex 4903-9237 electronic horn/strobe
The music room has a Faraday 5640 horn behind a Space Age Electronics AV32 light plate
The largest exceptional children classroom has a Federal Signal 450D horn with a VALS strobe
Located inside the largest computer lab, there is an Edwards 792 horn/strobe
Finally in the art classroom, there is a Siemens U-MMT horn/strobe set to continuous horn
Gentex SPK4
Casual Participant
Casual Participant
Wed Mar 07, 2018 5:02 pm
Here's another house....
A 3 story house, built in 1962, originally had an Edwards 1225 fire alarm system. Signals are Edwards 326 6-inch Bells. There was one bell on each floor. Under each bell was an Edwards 270-SPO pull stations. Edwards 241 Heat Sensors are installed on each floor, and in the boiler room. Signal coding was continuous.
The system stayed this way until around 1995, when it was replaced with an EST LSS4 system. The existing bells, pull stations, and heat sensors were removed. The new signals are EST 757-7A-HS Series Horn/Strobes, installed at each stairwell landing and in common areas (i.e. living room, kitchen, basement, etc), and Edwards 682-1A-HR Mini Horns installed in bedrooms, and EST 202 series strobes to provide additional strobe coverage where needed. Pull stations are EST 278B-1320s, and there are EST 6269B smokes scattered throughout, an EST 282B Heat Sensor was installed in the attic and garage. Also installed around this time was a Moose Z800 series security system, which also included the installation of several AMSECO door and window contacts, along with a NAPCO motion detector. The siren was a Faraday 10 Inch Bell.
In 2001, a Edwards Horn/Strobe in the basement failed to sound and was replaced with a Wheelock NS Horn/Strobe.
In 2005, a System Sensor i3 replaced a failed EST 6296B.
In 2006 a room in the basement was remodeled into the home theater room. So they tied an EST ANS100 VECP into the main FACP. The signals in the new home theater room are EST Genesis Speaker/Strobes (there are four of them in the whole room). An EST SIGA series smoke was installed to replace the existing EST 6269B.
In 2007, an Edwards 682 Mini Horn broke and was replaced with a System Sensor P2R Horn/Strobe.
In 2013, the whole house was remodeled along with the fire alarm and security systems. The new fire alarm system is an EST3X with voice evac. The new signals are EST G4R-S2 and GCHFRF-S2VMC series Speaker/Strobes replacing the existing horn/strobes. The ceiling mounted speaker/strobes are installed in the living room, dining room, and kitchen, wall mounted models are installed in the basement, hallways, and home theater room. EST Genesis Horn/Strobes are installed in bedrooms the master bath, and the laundry room, with remote strobes in restrooms and the garage. Pull stations are EST SIGA-278s, new smokes are EST SIGA-PSs, and new heat detectors are EST SIGA-HRSs. An EST 757 series horn/strobe is installed in the garage. All strobes are synced. For a fire alarm, horn/strobes do code-3, while speaker/strobes play a temporal whoop tone and a voice message.
As for the security system, it was upgraded to a ELK M1 Gold. New door and window contacts are installed to replace the existing devices. Two new ELK wireless motion detectors are installed in the living room, basement, and in the home theater room. Also installed are two Honeywell Glass Break Detectors. There is one keypad per floor. An STI Stopper station is installed as a duress alert to police in the master bedroom closet. For signaling they put EST GCWN-VMA strobes ceiling mounted in the living room, dining room, family room, and basement, and G1WN-VMA strobes everywhere else except in the bathrooms and garage. They also tied a monitor module from the M1’s siren output to the EST3X panel which plays a yelp tone and a pre-recorded voice message through the speaker/strobes upon the security system going into alarm. A Wheelock 10 Inch Bell is installed outside. Also a fire sprinkler system was installed and a Potter Horn/Strobe was installed outside to serve as a sprinkler alarm.
User avatar
Simplex 4051
Contact:
Thu Mar 08, 2018 1:58 am
This school is an elementary and a middle school combined so because of that, the system in the middle school section can vary from the elementary school section. With 908 students, this is how it is set up.
In most of the school, the alarms are Simplex 4051 horns on 4050-80 light plates with no "FIRE" lettering and are mounted on backboxes
Located in the health classroom which you can only get into by going through the gym which has FOUR 4050-80s+4051s is a Simplex 2901-9838 horn on a 4903-9101 strobe plate with the strobe at the top
Another classroom, the middle school art room has a Siemens U-HNH electromechanical horn/strobe
Over in the vocational education room that has a direct exit, the middle school exceptional children classroom and the music classroom are Edwards 894-1B electromechanical horn/strobe
The elementary school exceptional children classroom has a Simplex TrueAlert in it
Finally, the elementary school art classroom and the media center have Simplex GX-90 mini-horn/strobes
Gentex SPK4
Casual Participant
Casual Participant
Thu Mar 08, 2018 8:12 pm
This is based off a fanfic I saw years ago on Deviantart...
Walt Disney Middle-High School, originally built in 1985 as a High School, originally had a Simplex 4002 fire alarm system tied to each building via Fiber Optic loop. Signals for the most part are Simplex 2901-9806 Horns on 2903 Strobe Plates. These were installed in the corridors, main office, large classrooms, in the media center, cafeteria, auditorium, and gymnasium. Outside, they used flush mounted Simplex 2901-9806 Horns. Restrooms gained Simplex 2904 remote strobes. Pull stations are mostly Simplex 4521-20s, and there are a few Wiffleball Smoke Detectors and ESL Heat Sensors scattered throughout. Signal coding is continuous. As for the bell system they used “Dingers” (which were rebranded Wheelock speakers with a built-in chime tone generator). These “Dingers” were installed in the front office, media center, and hallways. In the cafeteria, auditorium, and gym they used Simplex 2901-9332 bells and Simplex 2901-9333 bells were installed outside. Classrooms had buzzers in the clocks. The master clock panel was a Simplex 2350.
In 1986, a Simplex 2901-9806 Horn outside one of the buildings failed to operate and was replaced with Wheelock 34T Horn.
In 1988, the Dingers began malfunctioning and couldn’t sound properly. They solved that problem by replacing the current Dingers with new ones. The Dingers produce a 550 HZ 60 bpm chime now vs the 425 HZ 120 bpm chime produced originally. Also a Simplex 2901-9806 in the gym got smashed and was replaced with a System Sensor MAEH horn.
In 1990, the strobe on the 2903 in one of the classroom buildings burned out. So it was replaced with a Simplex 4903 strobe plate.
In 1991, the Dingers malfunctioned again and died altogether. So this time, they took out the dingers, buzzer clocks, and bells. They also upgraded the clock and intercom systems, classrooms got new Simplex Clock/Speaker Combos and new Rauland call switches, everywhere else got new Rauland speakers. The intercom system is upgraded to a Rauland Telecenter and the school bell is now a 4-second tone over the intercom. The master clock panel is a Simplex 6400.
In 1992, a Simplex 2901-9806 horn in the Auditorium died and was replaced with a Simplex 2901-9846 horn.
In 1993, a Simplex 4521-20 broke and was replaced with a Simplex 4099. Also a Wiffleball smoke failed to operate and was replaced with a Simplex TrueAlarm.
In 1995, a Simplex 2901-9806 horn in the Media Center died, both it and the strobe plate was disconnected, removed, and a Simplex 4903-9217 horn/strobe took its place.
In 1997, a Simplex 2901-9806 horn in a science lab broke and was replaced with an EST Integrity Horn/Strobe which was slapped onto the strobe plate.
In 1999, a few more 2901-9806 (about 5) horns broke and were replaced with AMESCO Motor Horns, one was replaced with a Wheelock MT-WM Horn/Strobe.
In 2001, a small fire broke out in the metals lab. When the repaired it, they put in a Simplex TrueAlert Horn/Strobe, along with a Simplex 2099 pull station and a Simplex TrueAlarm smoke.
In 2002, three portable classrooms were put in. A Simplex 4005 was put in to serve the portables. Signals were Wheelock NS Horn/Strobes, set to code-3. Pulls were Simplex 4099s, and a Simplex TrueAlarm Heat Detector was installed in each portable. Also a Simplex 2901-9806 in the home ec room was replaced with a Simplex TrueAlert Horn/Strobe (the 2903 in this room was removed).
In 2005, big time changes came to this school as the Orange County School Board voted to convert this from a 9-12 High School to a 6-12 Combination Middle/High School. Three new 3-story classroom additions are built, along with a new high school office, larger cafeteria, and a HUGE sports center complete with an HUGE arena style gymnasium, an indoor basketball court, a large fitness center, and two new health classrooms, along with the renovation and expansion of the existing auditorium and media center, and the conversion of the existing gym, weight room, and cafeteria to Technology and ESE classrooms. The new additions have a Simplex 4100U INFOALARM network with the 4100U in the high school office serving as the master panel and the remaining 4100U INFOALARM panels serving as slave panels. A Simplex 4100U INFOALARM also replaced a 4002 serving the auditorium. The existing 4002s are replaced with one Simplex 4010 serving the existing buildings. Signals in the new additions and renovated areas are Simplex 4906-9127 TrueAlert Horn/Strobes. These horn/strobes are installed in the hallways, classrooms, and stairwells. Simplex 4906-9101 strobes are installed in restrooms and areas that didn’t need horn/strobes. Outside they put Siemens Weatherproof U-HNH-MCS Horn/Strobes. In the 1000 Building (Cafeteria), 7000 Building (Sports Center), and 400 Building (Auditorium, Band Room, Choir Room, Dance Studio), they used Simplex 4906-9151 Speaker/Strobes, except in the gym where they used Wheelock STH-1 Speakers mounted on the ceiling, and Simplex TrueAlert Remote Strobes on the walls, and in the indoor basketball courts where they used ceiling mounted TrueAlert speaker/strobes. The locker rooms have Wheelock E70WP speaker/strobes. Pull stations are Simplex 4099s, and there are Simplex TrueAlarm Smoke Detectors scattered throughout the new additions, as are Simplex Heat Sensors. Signal coding for the new wings is code-3 on the horn/strobes, and a Slow Whoop tone and a voice message for the 400, 1000, and 7000 building’s speaker/strobes. All the strobes are synced. They also upgraded the school’s intercom and clock system to a Bogen Multicom 2000, the class change bell sounds like this: https://www.youtube.com/watch?v=qJJa7QrzYms and the warning bell like this: https://www.youtube.com/watch?v=oxhiHgKJstQ
The clock system is integrated with the intercom system as well.
In 2006, some of the classrooms in the 600 building got Wheelock MIZ Horns because teachers complained they couldn’t hear the fire alarms to well. Also a few 4521-20s had to replaced with Simplex 4099s.
In 2010, they remodeled the 300, 600, and 900 buildings. So they replaced the existing signals with Simplex TrueAlert Horn/Strobes and Strobes. They also installed Wheelock ASWP horn/strobes outside. The pull stations were replaced with Simplex 4099s, and new TrueAlarm smokes are installed too. Signal coding is now code-3 in those buildings. Also the 4010 went bust and was replaced with a Simplex 4006.
In 2011, the 700 and 800 buildings were renovated. Same alarms etc as the 300/600/900 buildings.
In 2013, the 100 building was renovated, once again same alarms etc as the 300/600/900 buildings. Also the 4006 was replaced with a Simplex 4100ES.
The system is still like this to this day.
User avatar
Simplex 4051
Contact:
Fri Mar 09, 2018 5:50 am
This 880 student elementary school has a system put together like this.
In most of the school, the alarms are Simplex 2901-9833 horns on 2903-9101 strobe plates
Located within the entry vestibule, the alarms there are Simplex 2901-9806 horns on 4903-9101 strobe plates
One classroom, the art room has a Simplex 2901-9838 horn on a 4904-9501 strobe plate
Over in the computer lab, the alarm there is a Simplex 4903-9219 horn/strobe
The only preschool classroom in the school has a Simplex GX-90 horn/strobe
Finally, two hallways in the school, one above the other were renovated and got Simplex TrueAlerts instead
LSSD_2002
New Participant
New Participant
YouTube Username: NCAlarms
Sat Mar 17, 2018 6:11 pm
Notifier NFS-320 with ONLY Simplex remote lights and not a single initiating device to be found (except a dummied out monitor module to clear the no devices trouble). Now THAT's a fully functional life safety system there
User avatar
Simplex 4051
Contact:
Sun Mar 18, 2018 5:35 am
This elementary school that I am doing next fits 864 students.
Wheelock 7002Ts – All areas that are not mentioned
Wheelock 7002 – Up on the stage on the back wall
Siemens U-HNH – Fourth and Fifth Grade Wing
Space Age Electronics VA4 – Entry Hallway
Wheelock AS – Computer Lab
Wheelock MT-24 – Art Classroom
thegeet
Casual Participant
Casual Participant
YouTube Username: Cesar Blanco
Sun Mar 18, 2018 11:25 pm
Victoria High School was founded in 1935. The system was by Gamewell, with Edwards pulls, and Holtzer-Cabot horns throughout. Code was 4-4-4-4
In 1946, a cafeteria was added and had three Edwards 311D horns.
In 1952, a gym was added to the school, and had two Edwards 380 Adaptahorns.
In 1958, a pull rod was installed with the other devices. Additionally, a new wing was added to the school. That wing received Federal Signal 350's, but still operated with the Gamewell system.
In 1965, the pull rod broke down and was repaired. Additionally, a Holtzer-Cabot horn had stopped working, and was replaced with a Simplex 4037.
In 1970, a locker room had been constructed to stop using the middle school's locker room. It had four Faraday 5410's. Also, Chemtronics heat detectors were added.
In 1982, the old system had electrocuted and burnt. It was replaced with a Simplex 2100. The signals were taken down to place Simplex 2901-9838 in the hallways, and 9846 in the gym. 9833's were placed in the locker room. 9806's were installed in the cafeteria. All were placed alongside 2903 lights.
In 1993, 4903 strobe plates replaced the non-ADA 2903's which the horns were now mounted to.
In 1995, the school caught on fire, and the system was damaged by the sprinklers. The new system is a Notifier MS-4. There are NBG-12LX's, red Wheelock AS vertical strobe version or white ceilng mount MT's if there were white ceilings in the hallways, and Wheelock MT-24-WM outside the school. Classroom signals were either MT-24-LSM (wall mount), or LSM-24 strobes. Signaling was code-3.
In 2003, NS's and horizontal strobe MT's are added to new larger classrooms. Smaller classrooms had RSS's.
In 2008, a new floor was added. Signals were ZNS's in the classrooms only.
In 2012. SpectrAlert Advances replaced the few AS's that stopped syncing. Wheelock HSR's were added to the new auditorium (they had used the cafeteria before the auditorium was added).
In 2017, the panel was upgraded to include a third floor and another gym. L-Series horn strobes and strobes are added. The school is currently planning on a voice evac system.
#marshalbattsismyidol
Gentex SPK4
Casual Participant
Casual Participant
Mon Mar 19, 2018 12:23 am
Farwoods Middle School, built in 1989, originally had a Simplex 4002 fire alarm system. Signals were most Simplex 2901-9840 Horns on Simplex 2903 strobe plates. These signals were installed in the hallways, and some of the larger classrooms, they were also installed in the media center, gym, auditorium, cafeteria, band room, and choir room. Outside, they used Simplex 2901-9840 horns. Pull stations were Simplex 4521-30s. Simplex 2098 series smokes are installed throughout the school, as are ESL Heat Sensors. Signal coding was continuous. As for class change bells, they used a tone over the intercom system, the master clock panel was a Simplex 6400.
In 1994, a Simplex 2901-9840 in the cafeteria broke and was replaced with a FOS 6120 Horn.
In 1995, a Simplex 4099 replaced a Simplex 4521-30 in one of the hallways.
In 1997, two Wheelock NS Horn/Strobes were installed to replace broken signals.
In 2003, the fire alarm system was upgraded. The old Simplex system and signals were removed. A new Cerberus Pyrotronics MXL was installed. The new signals are CP U-MMT Horn/Strobes, set to code-3 horn. CP U-MCS Strobes were installed in the restrooms and areas needing strobe coverage. System Sensor SpectrAlert Classic Weatherproof Horn/Strobes were installed outside. An Audiosone Voice Evac Panel is installed in the auditorium, along with S-LP25-MCS Speaker/Strobes. Pull stations are CP MSI-20Bs, and CP DI series smokes were scattered throughout. The master clock and intercom systems were replaced during this time too.
In 2005, they installed System Sensor Exit Path sounders due to the AHJ requiring them to do so as a result of the Station Nightclub Fire.
In 2007, they added a new classroom wing. So they installed a Siemens XLS and tied it into the MXL. Signals in the new wing are Gentex Commander 3 Horn/Strobes and Strobes. Pull stations are Siemens rebranded RSG T-Bars, and System Sensor i3 smokes are scattered throughout.
The system stays this way to this day.
User avatar
Simplex 4051
Contact:
Mon Mar 19, 2018 1:35 am
An elementary school that is downtown has this setup with its 812 students has a setup like this.
Every single area that is not mentioned that is in the school has Simplex 2901-9806 horns on 2903-9101 light plates that blink in march time with projector cones attached
Down in the gym, the alarms are Simplex 4041 horns on 4050-80 light plates with "FIRE" lettering in black and they also have projector horns but instead of dual-projector horns like the 9806s, they have single-projector horns
The computer lab located next to the music classroom has a Gentex GMS horn/strobe
In the classroom wings, the six classrooms that are behind the fire door were renovated after a fire and got Faraday 5506 horns
Located in the community center playroom, there is a Wheelock AS-2415 horn/strobe
Last, the administration hallways have Simplex 4903-9237 horn/strobes
User avatar
idontwannaknow
Serious Participant
Serious Participant
Mon Mar 19, 2018 8:35 pm
Jovielle Middle School in North Carolina is an extra-large middle school that was built in 1985. The original system is a Simplex 4100 with Gentex SPK first-gen red wall speaker/strobes, including hallways, all classrooms, the gym, the cafeteria, all that. Individual teacher offices and restrooms received Gentex GXS red wall strobes. Pulls are Simplex 2099-9138s, and smokes are Simplex 2908-9201s, some small classrooms getting them installed on the walls.
In 1990, all three SPKs and the two 2099s in the gym received bars so they don't get damaged. One Gentex SHG horn/strobe was installed outside the school.
In 1996, the school got a new classroom wing attached, featuring TrueAlarms, Simplex 4903-9105 strobe plates with 4902-9703 speakers installed in hallways & classrooms, and Simplex 2099-9754 pull stations. One double classroom had a 4904-9105 installed with a 4902-9703 speaker on the other end. Bathrooms had strobes too.
In 2001, the cafeteria was updated, bringing in 3 Simplex 4903 speaker/strobes, TrueAlarms, and -9754 pulls. Computer Labs were also added with the same setup, only one 4903 speaker/strobe was put in each lab.
By the end of 2008, the system was replaced with a Simplex 4100U. All the -9201s had been replaced with TrueAlarms. Many classrooms had been upgraded in groups, resulting in Simplex TrueAlert speaker/strobes and a TrueAlarm on the ceiling. Some pulls were also replaced with 4099-9001s.
In 2014, the Gym had been fully modernized, given 4 Simplex 4906-9254 speaker strobes on the ceiling and Simplex 4906-9103 strobes beside both exits with 4099-9003 pulls under them. All appliances have protective bars.
The system remains.
draw
User avatar
Simplex 4051
Contact:
Tue Mar 20, 2018 1:57 am
Another elementary school on the other side of town that also holds 812 students has this system.
The majority alarms in the school are Gentex GMS horn/strobes
Inside the In-School Suspension Room, the alarm is a Faraday 5640 horn behind a 5415 light plate that blinks in march time
Over in the media center, the alarm there is an Edwards 792 horn/strobe
At the nurse's office, there is a Wheelock 7001 horn/strobe
Music in the school is done in a room that has a Gentex GOS in code-3 800 Hz
Finally, the stage area has System Sensor PA400R horn/strobes
