What 3rd pull station should I get?
User avatar
FireAlarmPanel347
New Participant
New Participant
Mon Dec 11, 2017 4:21 am
I am planning on getting a new pull station. I want you guys to decide what I should get. I narrowed it down to 3 pull stations. Vote Here: http://www.strawpoll.me/14596127
User avatar
Simplex 4051
Dedicated Participant
Contact:
Wed Dec 20, 2017 12:42 am
You can't go wrong with Simplex so that is what I voted for.
MayerFire
Casual Participant
Casual Participant
Wed Dec 20, 2017 2:05 am
Simplex 4051 wrote:You can't go wrong with Simplex
Unless you buy a TrueAlert with the intent of running it off three 9 volt batteries. Not criticizing them, just saying you can make mistakes while buying anything.
Rodj1
New Participant
New Participant
YouTube Username: Rodj
Wed Dec 20, 2017 7:34 am
MayerFire wrote:Unless you buy a TrueAlert with the intent of running it off three 9 volt batteries.
What's wrong with running it off 3 9-volt batteries?
User avatar
DJDiehl2K
Casual Participant
Casual Participant
YouTube Username: DJDiehl2K
Contact:
Wed Dec 20, 2017 8:11 am
Simplex uses a sync protocol called smartsync and if the horn/strobe uses smartsync, it can ONLY be run on a smartsync circuit. Otherwise the strobe will only flash one time when power is removed. This is different from other manufacturers because usually if you don't use a sync protocol, the horn/strobe would just free run. But Simplex smartsync horns and strobes will do nothing without smartsync.
Professional Can Opener
Commercial & Residential Burglary Alarm, Access Control, and CCTV Technician at Digital Media & Security
GE Concord 4 Owner | Fire & Burglary Alarm Enthusiast
View System Tests on YouTube
User avatar
FireAlarmPanel347
New Participant
New Participant
Thu Oct 11, 2018 3:23 am
I decided on the BG-10, as it has the most votes, I already have a BG-12 anyways.
User avatar
Simplex 4051
Contact:
Thu Oct 11, 2018 11:27 pm
I hope that you enjoy it then when you get it!
