Simplex 4005 Factory Reset?
firealarmgeek
YouTube Username: msj191961
Thu Dec 22, 2016 4:42 pm
I just have a quick question I wanted to ask before I proceed on.
I recently replaced the CPU in my Simplex 4005. This CPU has a custom level 4 programming access code; it is not the default. I need this code to remove all the old cards from the system and add the ones I have. I've tried so many different variations of the default code, but none have worked. So, I've just been taking some time and sitting down with the panel and guessing every single code from 0000 to 9999. I've tried about 1,300 codes so far (those being 0000 to 1300) with no luck, and this is getting pretty tedious.
My dad, who works as a building engineer and regularly deals with fire alarm systems and other systems, told me there HAS to be some way to factory reset it, like removing the CMOS battery (I don't think there is one) or there has to be a master code aside from the default that will log me in. Is this true? Because, from what I've heard, there is absolutely no backdoor into the 4005.
Someone commented on one of my YouTube videos saying something about jumping two pins somewhere to wipe it, but I don't feel comfortable doing that, considering the fact this is my 5th fire alarm panel and also my most expensive, and I'd rather not fry it. Heck, I got the thing fried and I just spent almost $200 in replacement parts. I'd really like to see it going.
If anyone has any solutions, please let me know. Thanks in advance!
Retired STR-SG
Moderator
Moderator
Thu Dec 22, 2016 6:22 pm
I am not aware of any way to factory default a 4005 without being able to log into the panel.
Watch for a PM.
firealarmveteran15
Serious Participant
Serious Participant
Fri Dec 23, 2016 8:40 pm
firealarmgeek wrote:I've tried about 1,300 codes so far (those being 0000 to 1300) with no luck, and this is getting pretty tedious.
Actually, that would be 1,301 codes, since you are including 0000.
HenBasket
Serious Participant
Serious Participant
YouTube Username: HenBasket
Sat Dec 24, 2016 10:19 am
frankalarms39 wrote:Actually, that would be 1,301 codes, since you are including 0000.
about
Roses are red, heavy steel beam
I need a rhyme to finish this meme
firealarmgeek
Sat Dec 24, 2016 7:33 pm
I got the code, with the help of Retired STR-SG. Thank you, everyone!
Have a Merry Christmas!
fabyo
Registered User
Registered User
Fri Feb 03, 2017 12:47 pm
Hi guys i have the same problem with a simplex 4008 someone can help me ?
Retired STR-SG
Moderator
Moderator
Fri Feb 03, 2017 6:39 pm
Hi fabyo, welcome to TFP forums.
Please introduce yourself here>>
viewtopic.php?f=1&t=5575&start=120
Simplex 2001
New Participant
New Participant
Mon Feb 06, 2017 9:15 pm
Yoypu can't do a factory reset on a 4005 only a simplex 4010
:!: do not read this :!:
Jack
Moderator
Moderator
YouTube Username: FireAlarmCollector
Tue Feb 07, 2017 3:11 pm
Simplex 2001 wrote:Yoypu can't do a factory reset on a 4005 only a simplex 4010
The OP's problem has already been solved.
Jack Kirkpatrick - Moderator
Reseller, Collector
ShopFireAlarms Website
FireAlarmCollector Site
FireAlarmCollector Youtube
Wwallender
Registered User
Registered User
YouTube Username: Dakota Wallender
Mon Mar 11, 2019 10:07 pm
I have a simplex 4010 panel that I would like to factory default. I can get into level 3, but I don’t have access to level 4. There is a password written on the panel but it does not work. What are the steps to reset this guy? I would like to put it in my house some day, but I can’t even learn how it set it up because it has an old config on it. Thanks in advance
