I have a retrofit. Are the E3 and Harrington the only options if I want to maintain the existing devices. I am searching for an alternative to these 2 panels. If there isn’t one I will have to replace every device.
Thank you for your input.
How many SLCs do you have?
Fci devices are NOT listed to work with Harrington. Might want to be careful there.
2 loops max-use an S3.
Otherwise E3 is your option. Camworks has an option to upgrade the 600 file to SLP file if you have it. You can then upgrade SLP to E3, but you will have device types to correct.
