I am getting my simplex 4002 today. But it was hooked up to the main power at the school that was torn down. Is it possible to wire it wrong, for example, reversed polarities, and blow the panel? I need to make it work with a standard wall outlet plug. Any help will be greatly appreciated.
The 4002 is a VERY fragile panel. Check your wiring twice before you plug it in–it’s really easy to blow something. If you get the polarity wrong, yes you will blow something. Good Luck!
