Fci 7100 Back Door
LifeSafety29577
Registered User
Registered User
Wed Apr 20, 2016 8:05 pm
Has anyone been able to successfully gain access to program the 7100-1D? I'm currently stir with two system with a customer whom want us to take over the central station. Does anyone have the ability to gain access without the current passcode?
Mkreilly26
New User
New User
Mon May 16, 2016 9:30 am
Could someone also pm me the passcode?
User avatar
U8oL0
Moderator
Moderator
YouTube Username: jjinc24
Contact:
Mon May 16, 2016 11:57 am
Just a reminder of one of our rules:
P8.* Do not publically post panel access codes or backdoor instructions. If you need to ask or tell someone a code, do it over PM.
IntegrityTech
Registered User
Registered User
Wed Sep 07, 2016 10:56 am
I have a customer whom is trying to change monitoring and the level 4 password has been changed from the default and the installing company is now out of business. Is there a backdoor to change back to default? I have seen similar posts, can someone please PM me the process?
kaptainkurk6065l
Fire Alarm Technician
YouTube Username: firealarmtech
Sun Sep 11, 2016 4:23 pm
IntegrityTech wrote:I have a customer whom is trying to change monitoring and the level 4 password has been changed from the default and the installing company is now out of business. Is there a backdoor to change back to default? I have seen similar posts, can someone please PM me the process?
Unfortunately there is no way to change the level 4 programming code unless you know it.
You have to be an FCI ESD to do so.
Collecting "Farr' larms" since 2006.
sglamorris
New User
New User
Sun Feb 05, 2017 3:43 am
I know this is an older thread, but I am also needing the level 4 passcode for our panel. We are locked out of it currently and cannot locate password to unlock. Thank you.
FireFireFire
Registered User
Registered User
Mon Apr 10, 2017 9:46 am
ccs46 wrote:I found the Level 4, I sent you a PM Newton.
User avatar
ccs46
Dedicated Participant
YouTube Username: ccs4646
Mon Apr 10, 2017 4:22 pm
Is it the default code? If you've been locked out of it, its more than likely been changed. Unless you know it, you have to get a tech to reset and unlock the panel for you.
Chris Sprague - Overseer of Sarcasm
QRFPFL
Registered User
Registered User
Sun Jun 04, 2017 12:37 pm
I am new to this forum and found it actually searching for the info on the 7100!! Great find for me great knowledge and conversations I see. Can someone please PM me the code as well?
Thank you in advance
MB-QRFPFL
Makusafe
Registered User
Registered User
Thu Jul 20, 2017 9:11 am
ccs46 wrote:
HRFiretek wrote:i know this thread is old, ccs46 can you please pm me the info as well, i am having same issues as above..
Thanks
PM Sent
Hate to revive this old tread, CCS46 would you be kind enough to share your wisdom, and PM the information to access the panel, I can seem to be able to get to level 4 with any of the codes I have on record
Thanks in Advance
ChanceGavin
Registered User
Registered User
Thu Aug 24, 2017 3:43 pm
Sorry to bring this up again. I'm working on a new account and all my current fci passwords are not working. Can someone send the default level 4 password to make sure I have the correct one for an fci 7100? I would post what I believe to be the correct one but I know that's the correct way of doing it. Thanks in advance for the help!
Sprinkler_guy
Registered User
Registered User
YouTube Username: Roman Pollock
Thu Aug 24, 2017 4:50 pm
I am also looking to find a way into a fci 7100. I just replaced the board with what was thought to be a new board. But it turns out it was used somewhere else. So the default level 4 code has been changed. And I just need a way to factory reset this thing so that it can be used. Thank you in advance for any help.
Sprinkler_guy
Registered User
Registered User
Fri Aug 25, 2017 9:46 am
Oreoman
Registered User
Registered User
Wed Sep 13, 2017 4:52 pm
please need help obtaining back door password due to password was already changed by previous installer.
fireproguy
Registered User
Registered User
Fri Sep 29, 2017 2:17 pm
Any info regarding level four access would sure be nice. Please PM me, we do have a client that needs our help and cannot get access since the installer is no longer available to help. We know how to scratch it and start over but seems silly and time consuming.
