Gamewell 600 series
Some time ago ,( 6 years ) I had to program several IF 624 and 632 panels, and even the odd 7200, I used SmartProgram III and it worked fine. recently I ran into an IF 610 and need to add an RCE ( addressable control relay ) to shut off a new MAU an HVAC contractor installed. I don’t have the cable that connects to P2 on the CPU board, but I suspect I can add the relay through the keyboard. If done wrong, the system programming gets wiped, and all input devices get defaulted as alarm. Not an idea situation ! I believe I can add the RCE and initialize JUST the addresable loop to add a new device… and not affect other device programming. but after 6 years I’m not sure. Anyone here with more recent gamewell experience ? Thanks !
Do you have the password to get into the program?
Hi, I have to program a IF610 and o dont have the pass level 4, I already tried the default pass and it does not match. Does anyone here have any ideia of how to reset the password of this panel? Even if erease all the program that is already there! Thanks
