Simplex 4010 factory default
JPN
New Participant
New Participant
Fri Apr 28, 2017 3:43 pm
Hi everyone,
I just scored a 4010 from a recent renovation. It's not my first panel as I've had a Gamewell Flex 402 and an EST Fireshield in the past, but the 4010 for sure packs a lot more punch and I'm super happy with it. Well, almost anyway. The level 4 passcode isn't the default code on the 4010. I was reading somewhere that there is a backdoor or way to reset it to factory default, is this true?
User avatar
Retired STR-SG
Moderator
Moderator
Contact:
Fri Apr 28, 2017 4:44 pm
Welcome to the forums. You might want to go to the general discussion forum and introduce yourself.
viewtopic.php?f=1&t=5575&p=73539#p73539
Since you are a new user and this is your first post I have to get verification that is is for a hobby system.
JPN
New Participant
New Participant
Mon May 01, 2017 12:50 pm
I suppose that makes sense so someone isn't just screwing around with a system maliciously... but anyway, yes you're right I should have introduced myself anyway :wink: I just posted in the topic, if you need to have further proof I'm going to post a collection video later today and I will include the 4010 in it.
JPN
New Participant
New Participant
Mon May 01, 2017 3:49 pm
I figured it out just now actually. Thanks though :D
nicklein
New Participant
New Participant
Sat Oct 21, 2017 9:33 am
Hi,
I am having the same issue. What procedure did you use. You an send me a private message if you'd like. Thanks
nicklein
New Participant
New Participant
Sat Oct 21, 2017 2:24 pm
Got it, :) Thanks for the PM!
Jared R
New Participant
New Participant
Wed May 30, 2018 4:41 pm
Can I also get a private massage on how to default the level 4 passcode on a 4010? Thanks a lot!
User avatar
Retired STR-SG
Moderator
Moderator
Contact:
Wed May 30, 2018 4:51 pm
PM sent.
rick4040
New Participant
New Participant
Sat Oct 20, 2018 2:59 pm
I have a simplex 4010 that I need to do a quick config on , but I can not do it because it is currently programmed for use of a DACT. (the dact must be programmed out via a pc programmer, which I do not have) Is there a way to default the panel, so it does not come set up with a dact card installed?
I have the level 4 programming password.
Thanks!
Rick
chris9359
Registered User
Registered User
Fri Nov 02, 2018 2:32 pm
I am having the same problem with my 4010 can you pm the info on how to reset the level 4 password. thanks
