Simplex 4005 CCDACT Programmer
jm2014
Casual Participant
Casual Participant
Sun Dec 31, 2017 8:58 pm
I'm planning to add a DACT to my 4005 but it needs an external programmer. So far all I know, it requires a DOS like interface and a programming cable, but does it need a dongle? If that's not possible, what external dialer can I use that will send zone and trouble information to the central station, not just FIRE ALARM or TROUBLE?
User avatar
Retired STR-SG
Moderator
Moderator
Contact:
Mon Jan 01, 2018 1:53 am
The Simplex 4005-9810 DACT is a "contact closure" type (CCDACT). The kit includes the circuit board, mounting bracket (installs below the CPU), and a 10 pin ribbon cable. Programming is done using the standard download cable and a terminal program. No dongle is needed. There is no option for a 4005 Serial DACT.
jm2014
Casual Participant
Casual Participant
Mon Jan 01, 2018 1:58 pm
Ok wonderful. So is this a DOS type terminal or standard windows terminal? Is there a manual for this as I would *extremely* prefer all components stay within the fire panel, including the dialer.
User avatar
Retired STR-SG
Moderator
Moderator
Contact:
Mon Jan 01, 2018 3:16 pm
DOS or Windows, like hyperterm, will work. The simpler the better. 9600,8,n,1 with Xon/Xoff handshake. This is a command line operation with the smarts in the CCDACT. Left a link to the manual in a PM earlier today.
Here is an example of the complete CCDACT kit.
https://www.ebay.com/itm/Simplex-4005-C ... SwF1dUSaS1
NEVER connect phone lines to a DACT until it is programmed for your application. If there is programming in the unit it will want to connect to a central station when powered up. That could cause an unneeded dispatch somewhere.
jm2014
Casual Participant
Casual Participant
Mon Jan 01, 2018 5:27 pm
Awesome! Thanks
jeremyy03
Registered User
Registered User
Fri May 18, 2018 11:13 am
Retired STR-SG, can you PM me that manual also please.
