So, I have a Fike SHP (Single Hazard Panel) which is a fire suppression panel that is conventional. I am having a problem with it where the AC transformer in it is getting really hot, and I mean too hot to touch. It has almost no load at all, it has a small module inside that is being used for a remote silence switch which is just two little leds running and the other thing running on it is an illuminated pushbutton abort switch. The only other thing using the transformer is the panel itself. Since it isn’t the most common or familiar panel i put some links to pictures of it.
closed- https://drive.google.com/open?id=1KcfetI1SnasExoiXia2DgjylL3wom5wH
open- https://drive.google.com/open?id=1-CEAWgOQfcgwV349rUbwbli_HFx9wJi8
interface- https://drive.google.com/open?id=1y6U9Q5qWClKunWllRmfHOhIQLof4YRFw
Help would be greatly appreciated as i can’t really run the panel 24/7 until i get it fixed.
