Simplex 4100 Legacy - Positive Alarm Sequence
ff803
New User
New User
Thu Sep 13, 2018 6:55 pm
I've tried searching online, but as I expected, not much success.
This need is for a school. Without getting into further detail, the environment at the moment would be greatly improved if the automatic detection devices/zones could be programmed for a positive alarm sequence. However, I know this panel was designed in the 1980's - but was top of the line back back.
Does anyone know if this panel is capable of "selective" (by zone/point) positive alarm sequence operation? As opposed to pre-signal... trying to keep from having to try to deviate from 101 Chapter 15.
Thanks for all who help
User avatar
Retired STR-SG
Moderator
Moderator
Contact:
Fri Sep 14, 2018 3:09 pm
Yes, any 4100 system can be programmed for Positive Alarm Sequence. It will take a Simplex (now JCI) technician to do the programming. I looked it up for a customer years ago (pre-4100U) while I was still working, however it was never implemented. A tech can get the documentation on the programming through the Technical Support department.
Positive Alarm Sequence has a number of requirements. Read this article for more information.
https://www.jensenhughes.com/blog/posit ... -sequence/
