Wheelock Safepath SP40S D5 Trouble
AlarmSystemTech
Casual Participant
Casual Participant
YouTube Username: AlarmSystemTech
Tue Sep 25, 2018 7:23 pm
What does it mean when the LED D5 located on the top of the board is flashing and the system is in trouble? According to the manual it says that it is a Amplifier Section Trouble, but I'm not sure what that exactly means or how to fix it.
User avatar
Retired STR-SG
Moderator
Moderator
Contact:
Tue Sep 25, 2018 11:24 pm
D5 blinking indicates a problem with the AUX input preamp. The following is from the manual for D5 blinking.
8.2.16 Procedure P
If the green PWR LED is "ON," the yellow SYSTEM TROUBLE LED is "ON," and D5 AMP LED is blinking, an Auxiliary preamp trouble has occurred.
Perform the following:
1. Turn Aux Volume Pot (R100) fully clockwise.
2. Initiate the AUX input if it is being used (via Remote MIC).
3. Reset power to the SP40S board by turning it OFF and reenergizing it. Remove battery power first, then remove AC power. Wait 30 seconds. Apply AC Power first, then apply battery power.
4. Replace the motherboard.
You can also try this.
Telcom & Data provides Nationwide techincal Support on all Wheelock Safe Path Emergency Notification Systems.We can help cross reference older Wheelock Fire Alarm horn strobes. Need technical support with your Wheelock product or need to cross reference an old part number? We can help find the right horn strobe, bell, amplifier or any other Wheelock parts.
Technical support can help. Call us at 800-335-0229
AlarmSystemTech
Casual Participant
Casual Participant
Wed Sep 26, 2018 8:56 pm
Thanks for the info, got system normal. Found out it was a dip switch setting on the motherboard used for the remote mic feature.
