Hey, new to the forum. I got a message on my keypad that my window sensor zone needed to be checked. Not a low battery, a check sensor. Its a Micra switch, wireless. I changed the battery, it worked for a day then again failed. I figured the switch was bad, got a new one. Same issue. I made sure the antenna wire was extended inside the vinyl window frame.
Could this be an issue with the panel or the wireless receiver at the panel?
