Resi Sprinkler System Flow Switch Wiring
An area to discuss extinguishers and suppression systems.
User avatar
kjhs09
Casual Participant
Casual Participant
Fri Jan 01, 2016 4:44 pm
I have been working on a rewire of a remodel, and the fire sprinkler system was recently put in. The riser is outdoors. The only thing the sprinkler fitters did was install the flow switch, which is a System Sensor WFDTN. What is the preferred method to wire a bell to one? I would assume running thwn in sealtite from the flowswitch to a weatherproof single gang, sealtite inside the wall to the bell backbox, fed off of a dedicated circuit?
The local grammar nazi!
User avatar
Robert A
Dedicated Participant
Contact:
Thu Jun 02, 2016 12:24 am
Does the system have a FACP? I know some places don't require a FA system if the building is fully sprinklered (or old enough to be grandfathered in). If it does (and the system is addressable) you could use a monitor module to hook that switch to the panel, and set it to only output the sprinkler bell if tripped.
Robert Aslin
If you need to contact me for any reason, you may email me at aslinrobert15(at)gmail.com.
User avatar
Robert A
Contact:
Thu Jun 02, 2016 12:27 am
Edit: Just realized it's a residential system. Yeah, you could run a bell off a dedicated circuit.
Robert Aslin
kmaysob
Fire Alarm Technician
Thu Jun 02, 2016 12:44 am
Standard practice is to use a 120v bell . The flow switch will be used to switch the HOTs only with the common and normally open contacts on one side of the switch . The other side will be reserved for a facp.
