If you look closely at the scope photo I posted the peaks of the half sine wave are flattened. That probably is due to the MOVs and other components in the power supply and across the NAC. It is possible that the flattened sine wave changes the sound of a mechanical horn. The clipped peaks make the sine wave seem more like DC. With every half cycle going to 0 volts it is obvious there is no filtering in the circuit.
Since nobody answered the 4100+ question, it is a 1,000 point panel. If the panel is part of a network the point total combines local hardware points and network external points. A 4100+ also can provide 2,000 annunciation points. That would be LEDs and switches.
When did Gentex stop production of the SHG/GLS devices?
[quote=WhelenSirenFan post_id=82515 time=1543438016 user_id=4540]
A: late 90’s, around when the commander series was introduced
Q: how long does it take for the Fire lite MS-9050UD to normally reset?
A: around 3 seconds, I used jjinc24’s video to count the reset time https://www.youtube.com/watch?v=ALwpRoMy3Yg
Q: What city used to be the former headquarters of simplex?
BTW, lets keep this topic going
[quote=RSSAlarms post_id=82605 time=1544296155 user_id=4672]
Gardner.
Now another question. What panel did simplex introduce in 2010-2011?
[quote=RSSAlarms post_id=82608 time=1544304655 user_id=4672]
4100ES, 4010ES.
I’ve got one…
How many wall-mounted visual notification appliances are required in a space that is 40x40 feet, and what intensity must the strobe be?
The reason it takes that one only 3 seconds is because when they are in trouble, they don’t reset. I also said on a normal reset. Other people I know who have 9050UDs or NFW-50’s (Notifier equivalent) say that they take around a minute and a half to reset normally. I have an NFW-50 and that’s how long it takes for me every time, regardless of the size of system.
My question: What year did voice evac start to become more prominent over using horns and bells?
Fire-Alert
(Fire Alert)
December 13, 2018, 5:55am
52
Q= what key dose a GE FIREWORX FG-3 use, Thanks!
[quote="Fire Alert" post_id=82646 time=1544680549 user_id=4868]
I think it uses the EST key.
[quote="Simplex 4051" post_id=82633 time=1544499479 user_id=18]
Voice evac was introduced in the early 1970’s and probably was mandated in high-rises (I think it’s 7 floors or more?) shortly after that.
[quote]
And that’s the CAT-45 key.
Fire-Alert
(Fire Alert)
December 14, 2018, 1:55am
56
[quote=RSSAlarms post_id=82652 time=1544715001 user_id=4672]
[quote]
Thanks!
Another question, what was the first addressable simplex panel?
[quote=RSSAlarms post_id=82659 time=1544764548 user_id=4672]
[quote=RSSAlarms post_id=82509 time=1543382119 user_id=4672]
Q: what candela rating was not used in the simplex 4903 TrueAlert series notification appliances?
Nobody answered this question yet.
[quote="Robert A" post_id=82612 time=1544311586 user_id=2817]
I believe the correct candela is 15cd (if I’m not mistaken) and the # of strobes required is 2. For the record, I used this as a source: http://www.cfaa.ca/files/flash/MEMBERSHIP/Fire_Alarm_Data_from_CHUBB_Edwards/Strobe_Application_Guide.pdf
MayerFire
(MayerFire)
December 16, 2018, 3:54am
61
What does the Braille text on the Fire-Lite BG-12 say exactly? (You can find a diagram with the Braille text in the pull station’s manual.)
