Clairmont Center for the Performing Arts- University of Mary- Bismarck, ND
This is the music building on this college campus. This college uses (and always has used) exclusively Simplex fire alarm systems. This building was opened in 1992. At some point in the last year, the system was upgraded to an addressable system, but the old notification appliances were kept.
Panel: Likely either a Simplex 4002 or conventional 4100 (replaced with 4100ES in 2025)
Notification Appliances: Simplex 2901-9838 horns on 4903-9101 strobe plates
Here are some photos I found online that show them:
Pull Stations: Simplex 4251-20s (Replaced by 4099-9006 addressable pull stations in 2025)
Detectors: Simplex 2098-9202 smoke and heat detectors (Replaced by 4098-9714 addressable smoke detectors in 2025)
Annunciator: Silver incandescent Simplex annunciator similar to this one: (Not my image)
Credit: @The09Creeper
In 2025, the door was replaced with a metal plate, and a 4603-9101 was flush mounted on top of it.
Clock System: Surprisingly, they didn’t go with a Simplex clock system. Instead, they have a National Time and Signal clock system. The NATSCO system is still in use, and is still keeping accurate time to this day.
Here is a photo I found online of a clock and speaker combo that can be seen in most rooms:
Upstairs, some rooms have separate ceiling speakers and wall clocks. I’m not sure if the intercom system is still in use, or what it could be. If it is in use, I’ve never heard anything from it.
Other photos from around campus that I took or found online:
These two photos below are from Arno Gustin Hall, which is an auditorium that was opened in 1970. Although it is connected to the Clairmont Center, it is on a separate 4100ES system (that likely used to be a 4100+) for many other campus buildings that was installed a few years earlier. All of these other photos (including the one above) are from that system. These older devices under a grate are no longer used.
