[quote=53zamar17 post_id=81862 time=1538356359 user_id=4752]
[quote=EdwardsFan post_id=81630 time=1536877130 user_id=85]
If they are disconnected and are wired right, the fire panel should be showing a fair bit of troubles.
Hi Edward,
Our building uses MH-24W mini horns like the ones attached. Now Mircom makes a newer model, which can be paired with http://www.mircom.com/media/datasheets/CAT-5224_CNSIS-204_Non-Supervised_Signal_Isolator_Module.pdf CNSIS-204 signal isolator module.
Could you explain some details of their wiring diagram? How exactly the mini horn, signal isolator, panel work together? Why wires in the unit boxes are twisted pair, actually dual wires hooked to each mini horn contact (see typical suite box pics)?
What happens, if a tenant simply bypasses the mini horn and hooks together in and out wires? Can the missing mini horn be identified on the panel, and how? If yes, why annual fire alarm check is needed in each suite?
Well there are 2 ways these mini horns can be wired. 1 way is using the isolator modules, which basically the modules have voltage in and voltage out. The wires coming from the panel would go into the voltage in, then there are 4 separate wires for the mini horn, 2 going in the unit and 2 coming out. The isolator that you put in that link does not show a trouble on the panel if the tenant disconnects the mini horn, but it should show on the isolator that mini horn is serving. The other way they would be wired is using a class A circuit. What that is, is that 2 wires come from the panel, to each mini horn, then 2 wires go back to the panel instead of having an end of line resistor. What that does is if someone takes their mini horn off in a unit, then the others won’t be affected.
I have no idea why the electrician installing that system used those tiny telephone wires. Knowing electricians though, they do mess up a lot when it comes to fire alarms. Don’t understand why you need an electrician to wire up fire systems when they aren’t even 110v anymore. They should be actual fire alarm wire, that cable inside is normally used for telephone/intercom systems. Why there are so many in the box is cause telephone wire has about 20 or so wires inside. What fire panel is in the building right now? If tenants are disconnecting wires to the mini horn, then the panel should have troubles on it. I don’t think any tenants should even know how to disconnect a mini horn and put the right wires back to not cause a trouble. Annual inspections are mandatory, and its needed because the fire tech needs to make sure each mini horn in each suite is working correctly.
I hope I answered all your questions.
