Just a little helpful info, an addressable pull station compatible with the 9600 is the Fire Lite BG-12LX and as far as I know that’s the only addressable pull station they manufacture. If you would want to use some of your conventional pull stations on your collections on your system with the 9600, you would have to get a Fire Lite MMF-300 monitor module, you would need one module per conventional device on the system.
