Gentex LED Commander 5 Signals
I honestly have no idea why Gentex kept the Commander 2 line around even after basically replacing it with the Commander 3: they could have had the Commander 3 take over everything the Commander 2 did & better, with horns, horn/strobes, & remote strobes, yet Gentex still kept on selling the Commander 2 horns & horn/strobes even though the latter is fixed-candela & the former could have had a Commander 3 model made to replace it so that everything belonged to the same series (at least now though the Commander 5 will likely be replacing all of the previous Commander product lines so everything will be uniform).
Actually, the Commander 2 strobes post Commander 3 release were for candelas that the Commander 3 could not do, such as 15/75 and 177
As I said though, could Gentex not have developed Commander 3 versions of those Commander 2 models so that everything would be part of the same series & they could get rid of the Commander 2 line completely? (though I suppose this doesn’t matter if the Commander 5 line will replace all of its predecessors)
What is the difference between 15/75 Candela and the 15 and 75 Candela setting on the Commander 3?
I don’t want the Commander 3 and 4 to go away. Those are My Favorite Gentex Models. And they are super reliable.
“15” & “75” are both separate candela settings, “15/75” on the other hand kind of “combines” the two: the strobe is 15 candela from the side & 75 from the front (no idea how that works or why it’s seemingly necessary but yeah).
Well like I said the Commander 5 will likely replace all of its predecessors due to the advantages you get with LED strobes, so they might. Even if they do they had good long production runs.
I mean, the Commander 3 is just a multi-candela Commander 2.
ADA was first introduced before the introduction of UL 1971, so strobes were required to be 75 candela under UL 1638, which only considers the candela directly in front. This resulted in strobes such as the Wheelock WM and Faraday 5522-U that provided over 100 candela directly in front of the strobe while minimizing current draw.
On the other hand, UL 1971 requires the strobe intensity at various angles to be a certain percentage of the overall intensity rating, and strobes whose intensity ratings would fall below 15 candela were not UL 1971 listed. This resulted in the creation of the 15/75 candela strobe to meet the 15 candela minimum of UL 1971 and the 75 candela requirement of ADA (which follows UL 1638). More recently, 15/75 candela strobes have become mostly obsolete due to ADA being updated to be consistent with NFPA codes, but some manufacturers such as Mircom have introduced new 15/75 strobes in recent years.
Oh: is that the reason for WM-series strobes? Alright, good to know: honestly thought they were made mainly for outdoor applications which would require super-bright strobes (though maybe they were just the same. Those requirements would also explain the semi-frosted lens too).
15 candela is the required minimum nowdays last I checked so why anybody wouldn’t make strobes that weren’t at least 15 candela I would have no idea.
Ah okay. Yeah it was rather stupid that the standards of two different organizations would differ like that: glad they’ve since been brought on an even playing field so that 15/75 strobes will no longer be necessary.
If they Discontinue the Commander 2, 3, and 4 then I will have no Alarms that are still being Made. Besides my EST 278/9Bs.
Edit: I made this Comment along with some other ones in this post when I first joined the forum and as a result was kinda immature.
I am really hoping that Gentex can Include testing ports as well as a magnetic metal mounting bracket as well as screws that you can use to mount the alarm without having to remove the beauty plate when installed.
I also hope that Simplex on the other hand does not make their LED Devices limited. It would be better if it was permanent. Their xenon strobe tubes are huge and last a short time, so it would be nice if they at least found an LED retrofit as well as better building quality. I think Simplex should definitely make a Simplex TrueAlert Strobe Plate that’s selectable for Free Run and SmartSync! I also think Simplex could make Single Gang LED Conventional TrueAlerts. That would be nice! I feel as if Simplex is very overdue on finding replacements on the 4906 TrueAlerts, however recently, they changed the logo on the SmartSync and Free Run TrueAlerts. So all in all, I think they should definitely find a replacement for the Conventional TrueAlert line sometime in the next year. These replacements if Simplex made it, would also apply to the Fixed Candela SmartSync 4903-9417, 9418 and 9419 Horn Strobes. It just has to be any horn strobe older. The ceiling strobes are a huge pain to remove, which makes me think that they should move on to something much simpler
Run-on sentence aside, the point of the beauty plate is to hide the screws. Having screws accessible without removing beauty plate defeats the whole purpose.
There are several things to respond to there, but this is a thread on the Gentex LED signals, not the Simplex ones.
Considering System Sensor did with their LED NAs (though I believe Wheelock beat them to that by quite a few years with their Exceder series) I don’t see why they wouldn’t: it’s a novel & innovative feature for techs in the field.
Compared to LED strobes xenon strobes definitely don’t last as long, yes, but just the same it’s not like they’re flashbulbs that burn out after a single use: they’ll still last for quite a long time & thus will still work for the time being.
Yeah, which is why a lot of notification appliances made during this century so far have their screws hidden (except for outdoor devices which apparently need the screws to be accessible from the front for some reason).
Personally I wish they looked like the Commander 1/2/3 but with an LED Strobe. The Design of the Commanders excluding the Commander 4 is very unique and stands out from other Alarms.
I wish the colors were consistent on the red and white units. The gray weirds me out
Yeah, would be nice, especially since basically no other companies have apparently realized that their existing signals’ designs should work for LED devices with minimal changes for some reason, but the designs as they are in the photo near the top of this topic don’t seem that bad either.
Looks white enough to me (& even if something is off about the color Gentex might have that fixed by the time they’re introduced).
I hope the commander 5 will be just as good or better than the commander 3,4 and speaker strobes. I wonder if the 5 will be similar to the 3, in that it has multiple tones along with a low frequency tone. From the images it looks like there is no dedicated ceiling or wall mount model.
Yeah, same here: sure hope Gentex keeps on being the excellent life safety manufacturer that I’ve known them to be up until now (particularly if they include one particular feature that’s been standard on their previous signal lines).
I’d say it would just make sense to incorporate a low-frequency tone to lessen the amount of individual models needed.
Maybe, which would be another way to shorten the list of models required to be made.
Does anyone know if they are keeping the Commanders 2, 3, and 4 in production? Or are those being discontinued?
Pretty sure the plan is for the Commander 5-series to replace all existing/previous Commander serieses, along with probably some non-Commander device serieses like their speaker/strobes too (which makes sense if the 5s can fill both the wall & ceiling-mount applications that the 3 & 4 can respectively, along with of course the 5 having so many advantages with their LED strobes (thus meaning there’s no reason to keep the older & fewer-advantage xenon devices in production).
