Identify Smoke Detector
That sounds great. Thanks for the suggestion and for conferring with your friends.
But I think my main issue right now is the power. I could maybe skip the two wires (of the four shown) that are supposed to be for interconnectivity. But going by my BRK alarm specs on the label shown in my previous picture posted here, there is an AC power input wire, and a DC power input wire to the alarm. I am not sure which, if any, wire is supposed to be neutral when installing a new alarm.
It’s not an SA76RC. Those are made by Smoke Alert / First Alert and they are battery operated.
What you have is an extremely rare BRK 79LVRI which by the way from what I’ve learned is NOT 120V AC. I believe those are wired DC powered but not even I know for sure even though I am an expert on BRK Electronics smoke alarms. There may be a side label having the model, voltage rating, branding, etc. Replacing those may be a huge task unless you just go to battery operated smoke alarms, if not your whole system may have to be converted from DC to AC.
Yours is even more special from the ones we know of to exist because of the three extra curved slots which is known as a ā€œbanana hornā€ style buzzer/beeper.
Whatever you do, DO NOT TRASH THE ALARM. Sell it on eBay if anything and if you ever do that please let me know.
Taking a closer look, your best bet may be to go with wireless only alarms. As your alarms appear to be connected to 12v DC and not 120v AC. At this point I don’t think you would want to mess with the electrical wiring. I’d recommend the first alert SMCO500V as a replacement.
Yeah do not recycle or throwaway these alarms the are VERY valuable.
So…the circuit breaker in my electrical panel that I turned off to power off my alarm system is actually a DC circuit breaker?
It should be a 120V breaker. I believe there is a transformer somewhere between the breaker and the power being fed to the alarms. How ever it could be connected to something like a security system.
OK. I guess it is electrician time. Ha.
I see a transformer, but I’m just a bit at a loss at this point on how to safely power your ā€œalarm with wireless interconnectivityā€ suggestion. This is above my pay grade. Haha.
…unless there are 9V battery powered alarms with wireless interconnectivity. But would that even be attainable with 11 alarms throughout my family member’s house?
Thanks for everyone’s input.
Wired DC!? Never heard of that before! Does that mean that there’s a transformer (& maybe bridge rectifier too) somewhere in the circuit to supply them with the correct voltage?
Really? Huh, had no idea there was a term for that older BRK/First Alert horn design.
Yes: I always try to emphasize that anytime someone’s looking to replace an alarm: a device saved is a device preserved one could say. According to the OP they have 11 of these super-rare BRK detectors, so Bassick, make sure that all 11 end up in good hands, okay? (& fully intact/working/with anything that comes with them for that matter) This community will thank you greatly for doing so.
There are such detectors, no idea what the interconnect limit or how effective each one’s range is though.
Here is the only transformer in the house. Since the security system is powered in a different way, this transformer has to be for the smoke alarms.
Couple things though: first off, its output is seemingly marked as ā€œ24Vā€, whereas those detectors need 12V. Second, unless there’s a bridge rectifier somewhere else in the circuit they’d be getting AC power rather than DC power. Third, that transformer doesn’t even appear to be connected to anything going by the lack of wires attached to the power output terminals!
Ok. Like I said previously…electrician time!! Ha.
I was referring to wireless smoke and co alarms that are powered only by batteries (2 Dubble As)
Oh, another thing…
Most modern security panels output 12VDC, so there’s a chance that those detectors are powered by it after all (security panels are usually powered by a 16.5VAC plug-in transformer, but that’s separate from the 12VDC that they output).
I’m not sure how modern a date you are referencing, but this alarm system has been in place for at least 40 years, according to my Father-in-Law.
ā€œmodernā€ as in the start of the 21st century I guess, but you’re right: forgot about that. I have an Ademco 332R security panel from 1977, & it’s 6VDC (12VDC wasn’t always the standard voltage). If that place’s security system is from 1984 as a calculator tells me though, there’s a somewhat-likely chance that it’s 12VDC (if you snap some photos of it we might be able to tell).
A few things I noticed, which really don’t have to go with the smoke alarms
  1. Your breaker panel has mixed breakers, which I’m sure is not safe
  2. What the heck is that red stuff all over the breakers?
  3. That transformer says ā€œHoneywellā€, so, I guess there’s that
