Are all your modules and detector bases wired properly, e.g. for bases with terminal 4 facing the panel and 7 toward the end of line? Have you checked voltage and/or resistance at the end of SLC line and compared it to the panel specs? Have you called tech support? I would focus on the “amp value too low” trouble, this indicates a poor wiring condition which can lead to extraneous troubles like dirty detectors.
