Shielded FPLR question
You’ll probably be okay if this is in an existing building where you are using existing shielded wire or replacing the panel, etc.
I’d at least recommend you put something in writing to the building owner or his/her rep saying the manufacturer’s installation instructions state to use unshielded cable to cover yourself in the event it does cause problems. This way they can’t say you didn’t tell them and you did your due diligence.
