I did an experiment with a resistor substitution box and a voltmeter across the IDC. I magnet tested my detector and then began switching in additional resistance across the IDC. The LED stayed on with 5 volts across the IDC. The next step lower dropped the IDC to 3.7 volts. The detector LED went out.
If you have a voltmeter check the voltage across the IDC in standby state and with the detector activated. The LED could be turning off because the IDC voltage is low.
Ah, then that must be it then. Next time I have the opportunity to test everything I will run a test with the voltmeter and see what happens.
