That’s actually a 2-wire smoke, by how it is wired.
In that case, you will now have to check Simplex’s documentation on 2-wire smoke detector compatibility before you connect this to your panel. Most of the time it won’t be a problem if it is not compatible but sometimes the results could be disastrous such as a fried zone, or unexpected such as the zone going into alarm while the detector is not in alarm.
