Fully Functional 5x5x2 Minecraft Fire Alarm Panel
This is where users can post any videos, recordings, or photos they have made that is related to fire alarms,
Forum rules
You are only allowed to post YOUR videos here. Please refrain from posting others videos.
User avatar
4j25
Casual Participant
Casual Participant
YouTube Username: 4j25
Fri Dec 05, 2014 5:44 pm
So, I know that some people would rather me not clog this forum with Minecraft designs, but I am fairly proud of this one and figured it deserved to be shonw to the public. So with that said, I present to you, the Mine Fire Systems Ltd. FireMaster FSCS-100, WITH instructions! (Please do not build and try to pass it off as your own, thanks!)
MINE FIRE SYSTEMS LTD. FIREMASTER FSCS-100:
ImageMinecraft Panel Instructions 1 by 4j25Sirens, on Flickr
ImageMinecraft Panel Instructions 2 by 4j25Sirens, on Flickr
ImageMinecraft Panel Instructions 3 by 4j25Sirens, on Flickr
ImageMinecraft Panel Instructions 4 by 4j25Sirens, on Flickr
ImageMinecraft Panel Instructions Chart by 4j25Sirens, on Flickr
ImageMinecraft Panel Instructions NAC by 4j25Sirens, on Flickr
ImageMinecraft Panel Instructions IDC by 4j25Sirens, on Flickr
ImageMinecraft Panel Instructions Aux. by 4j25Sirens, on Flickr
And that's it! Enjoy using this in your Minecraft creations!
______________________________________________________________________________
Copyright MFSLTD. 2014
Proud owner of a Simplex 4002 panel! :D
User avatar
Jack
Moderator
Moderator
YouTube Username: FireAlarmCollector
Contact:
Fri Dec 05, 2014 7:54 pm
Nice!
A few of my friends and I are on a Minecraft server where fire alarm systems are required in buildings (RPG style you could say). I have a company called Quick Alert (coming from that panel I built).
I have some competition though, and our panels are getting more advanced everyday. That system reminds me of an old Quick Alert 1000 series panel that was demolished along with a building a while ago, but it used a lot of the same mechanics.
I'll post some pictures of newer systems after I ask the admin if I can.
Jack Kirkpatrick - Moderator
Reseller, Collector
ShopFireAlarms Website
FireAlarmCollector Site
FireAlarmCollector Youtube
User avatar
4j25
Casual Participant
Casual Participant
Fri Dec 05, 2014 8:42 pm
Is that server public or private?
User avatar
Jack
Moderator
Moderator
Contact:
Fri Dec 05, 2014 8:51 pm
Private until Bukkit 1.8 comes out.
Reseller, Collector
User avatar
4j25
Casual Participant
Casual Participant
Fri Dec 05, 2014 9:39 pm
Oh okay. I can't join, can I? :C
User avatar
ccs46
Dedicated Participant
YouTube Username: ccs4646
Fri Dec 05, 2014 11:56 pm
mytechtime wrote:Private until Bukkit 1.8 comes out.
IF it comes out. Since Microsoft is buying MineCraft, some of the devs for bukkit are quitting... At least that's what I heard.
Chris Sprague - Overseer of Sarcasm
User avatar
ccs46
Fri Dec 05, 2014 11:57 pm
User avatar
Jack
Moderator
Moderator
Contact:
Sat Dec 06, 2014 1:14 am
They're already past that, and are developing code to compensate for the code taken down when some devs quit.
Reseller, Collector
User avatar
Robert A
Contact:
Sat Dec 06, 2014 12:32 pm
There's a Furniture Mod for 1.7.10 that allows you to install "fire alarms" (smoke alarms) that give off a redstone signal when set off. I suppose you could use those as smoke detectors if you want. They also have built-in sounders, but they don't interconnect.
Robert Aslin
If you need to contact me for any reason, you may email me at aslinrobert15(at)gmail.com.
User avatar
NewAgeServer
Administrator
Administrator
YouTube Username: NewAgeServerAlarm
Contact:
Tue Dec 09, 2014 10:45 pm
Alertek MFP-4 fire alarm control panel. This model has 4 zones. 5x8x6
Baseline model with one zone is 5x5x6, and is able to automatically detect fires and sound the alarm.
Here's a larger one with 5 zones installed in a fire station.
Andrew Davis -- Chief Administrator & Site Owner
The Fire Panel & The Fire Panel Forums
All questions or concerns, please PM here or email at newageserver@thefirepanel.com
My Fire Alarm Site
YouTube Channel
User avatar
Robert A
Contact:
Tue Dec 09, 2014 10:53 pm
How can it tell between detectors and push stations? And what do you use as detectors? I'd assume the "push stations" are stone buttons on an item frame containing red wool or something to that effect... In that case they'd be more like call points.
Robert Aslin
User avatar
Jack
Moderator
Moderator
Contact:
Tue Dec 09, 2014 11:33 pm
Pictures of some Quick Alert installations will be uploaded tomorrow.
Reseller, Collector
User avatar
NewAgeServer
Administrator
Administrator
Contact:
Wed Dec 10, 2014 3:10 am
Netscape128 wrote:How can it tell between detectors and push stations? And what do you use as detectors? I'd assume the "push stations" are stone buttons on an item frame containing red wool or something to that effect... In that case they'd be more like call points.
This panel is command block based.
The push stations are a stone button on a red stained clay block with a sign above that says FIRE ALARM. When you press the button it activates a command block behind it that puts a redstone block at the panel, sounding the alarm and lighting up the lamp for the pull station.
The detectors are command blocks. I've got a command on a loop that looks for fire (which is a block type) and outputs redstone power and activates the panel if one is detected.
The MFP-4 panel is highly successful because it's very easy to install and program, is expandable up to 15 zones before a "Zone Repeater" module is required, and it's real reliable.
I'm currently working on a revolutionary new panel called the AFP-200 (yes named after the Notifier panel). AFP in this case means Advanced Fire Panel, while MFP means Modular Fire Panel.
My Fire Alarm Site
YouTube Channel
User avatar
NJMoo3652
Casual Participant
Casual Participant
YouTube Username: NJMoo3652
Contact:
Tue Feb 03, 2015 10:47 pm
About video games, I think that it would be cool if someone released a fire alarm knowledge edition of the popular game "trivia crack"...... Jk
Official Account of NJMoo3652
Operator of FireSafetySales eBay Store
Feel free to PM or email me with any questions!
User avatar
NewAgeServer
Administrator
Administrator
Contact:
Tue Feb 03, 2015 11:31 pm
FYI this topic is 2 months old... please don't bump old topics.
My Fire Alarm Site
YouTube Channel
