Daily Fire Alarm Question!
User avatar
RSSAlarms
Serious Participant
Serious Participant
YouTube Username: RSSAlarms
Contact:
Now a question: Which zones on the Simplex 4002 are reserved for (a) coded pull stations, and (b) waterflow?
A: for coded pulls, it’s zone 1 and for water flow, it’s zone 7, if this isn’t correct, I’ll ask the Retired STR-SG if he knows what the zones are.
Q: When did simplex first start manufacturing the TrueAlert/QuickAlert series horn strobes?
”what is your major malfunction; numbnuts?”
-R. Lee Ermey
User avatar
randomperson
Serious Participant
Serious Participant
YouTube Username: randomperson Fire Alarms
Contact:
RSSAlarms wrote:
Thu Nov 22, 2018 4:20 pm
2000.
Posting fire alarm systems from eastern Massachusetts (and a few other places) since 2017.
YouTube
Email: everysingletrouble3 -AT- gmail -DOT- com
User avatar
RSSAlarms
Serious Participant
Serious Participant
Contact:
Q: when did STI first release the stopper covers?
-R. Lee Ermey
User avatar
ConorTheFAguy6
Casual Participant
Casual Participant
YouTube Username: CJ9899
RSSAlarms wrote:
Fri Nov 23, 2018 4:24 pm
A: early 90’s
Q: what was Simplex’s only FWR panel?
Life is like a free box of fire alarm parts, you never know what you are going to get
User avatar
RSSAlarms
Serious Participant
Serious Participant
Contact:
A: simplex 4208
Q: when did simplex discontinue the 2120?
-R. Lee Ermey
User avatar
Chase Reinhardt
Casual Participant
Casual Participant
YouTube Username: Firealarm237
Contact:
RSSAlarms wrote:
Mon Nov 26, 2018 12:24 pm
A: simplex 4208
A: 1992
Q: How many points does the 4100+ have?
User avatar
Retired STR-SG
Moderator
Moderator
Contact:
ConorTheFAguy6 wrote:
Mon Nov 26, 2018 10:54 am
A: simplex 4208
I can add one to the answer. The NAC on the 4001 also is FWR. Scope photo below of 4001 NAC with 1/2 amp load.
User avatar
RSSAlarms
Serious Participant
Serious Participant
Contact:
never knew that the 4001 had FWR.
-R. Lee Ermey
User avatar
Simplex 4051
Dedicated Participant
Contact:
OK new question. When did the second generation Gentex SHG first come out?
User avatar
RSSAlarms
Serious Participant
Serious Participant
Contact:
A: 1999
Q: what candela rating was not used in the simplex 4903 TrueAlert series notification appliances?
-R. Lee Ermey
User avatar
nightfly287
Retired Staff
Retired Staff
Retired STR-SG wrote:
Tue Nov 27, 2018 4:53 pm
To an enthusiast, the difference between filtered and FWR is whether or not mechanical horns sound raspy. How come mechanical horns on a 4001 don't sound raspy? Can a panel output FWR but not to the level where it affects horn operation?
nightfly287 -- Director of Sarcasm
User avatar
Retired STR-SG
Moderator
Moderator
Contact:
If you look closely at the scope photo I posted the peaks of the half sine wave are flattened. That probably is due to the MOVs and other components in the power supply and across the NAC. It is possible that the flattened sine wave changes the sound of a mechanical horn. The clipped peaks make the sine wave seem more like DC. With every half cycle going to 0 volts it is obvious there is no filtering in the circuit.
Since nobody answered the 4100+ question, it is a 1,000 point panel. If the panel is part of a network the point total combines local hardware points and network external points. A 4100+ also can provide 2,000 annunciation points. That would be LEDs and switches.
WhelenSirenFan
I'm Banned!
I'm Banned!
YouTube Username: WhelenSirenFan
When did Gentex stop production of the SHG/GLS devices?
Welcome to Northern Michigan! Where will you not find a building with an EST Genesis?
User avatar
ConorTheFAguy6
Casual Participant
Casual Participant
WhelenSirenFan wrote:
Wed Nov 28, 2018 3:46 pm
A: late 90’s, around when the commander series was introduced
Q: how long does it take for the Fire lite MS-9050UD to normally reset?
User avatar
RSSAlarms
Serious Participant
Serious Participant
Contact:
A: around 3 seconds, I used jjinc24’s video to count the reset time
Q: What city used to be the former headquarters of simplex?
BTW, lets keep this topic going :)
-R. Lee Ermey
