Pull stations should not be used as light switches.
Housedays
Serious Participant
Serious Participant
Thu Jun 20, 2019 7:04 am
They just aren't designed for that purpose and ironically it can start a fire.
User avatar
RSSAlarms
Serious Participant
Serious Participant
YouTube Username: RSS alarms
Contact:
Thu Jun 20, 2019 3:52 pm
It can if your pull station’s switch is not rated for the voltage that you are going to pass through it.
I've been an enthusiast since 2009, but haven’t started collecting until 2016
User avatar
RSSAlarms
Serious Participant
Serious Participant
Contact:
Thu Jun 20, 2019 4:03 pm
A good example would be the Edwards 270-SPO’s switch. It is rated for 30VAC and 60VDC at 3 Amps. If you were to run 120VAC at 15 Amps through the switch, it would probably melt the switch.
User avatar
Simplex 4051
Dedicated Participant
Contact:
Thu Jun 20, 2019 7:21 pm
Never really realized that the voltage for a house's electrical system is much more substantial than the voltage for a pull station. I always thought it was the other way around for some reason.
User avatar
nightfly287
Wiki Team Member
Wiki Team Member
Thu Jun 20, 2019 9:33 pm
Even if a pull station is rated for the appropriate current/voltage, most lack an earth connection (ground screw) which could cause a fire under the right circumstances (i.e. lightning strike, internal device failure/short circuit).
nightfly287 -- Director of Sarcasm
simplexspectralert
Casual Participant
Casual Participant
Sun Jun 23, 2019 1:03 am
i saw them in a goanimate video
User avatar
RSSAlarms
Serious Participant
Serious Participant
Contact:
Sun Jun 23, 2019 1:09 am
What video? Please be specific, no more vagueness.
User avatar
idontwannaknow
Serious Participant
Serious Participant
Sun Jun 23, 2019 1:10 pm
If voltage wasn't an issue, how would you turn the lights off if you lose the key, because that could be another problem.
he/any. typically bored on a wednesday evening.
User avatar
Robert A
Contact:
Sun Jun 23, 2019 1:29 pm
Yes, because GoAnimate is the paragon of realism.
Robert Aslin
If you need to contact me for any reason, you may email me at aslinrobert15(at)gmail.com.
User avatar
htsmi
Fire Alarm Technician
Sun Jun 23, 2019 4:56 pm
Just please be careful. It's fun to play around with these things, and I've done it in the past. But if your house burns down, even for an unrelated reason, and they find evidence of DIY wiring that is not up to code, they can use it to deny all or part of your claim. They are ruthless like that and have no qualms about bankrupting your family. Just keep that thought in the back of your mind.
User avatar
Simplex 4051
Contact:
Sun Jun 23, 2019 5:09 pm
I wouldn't screw around with any of it at all because this house I'm living in was built by my great-grandpa Vincenzo who I never met and 3 generations grew up in it. Also there are 10 people living here on 2 floors and a basement apartment.
