If possible to send programming setup. For simplex 4100u, es programmer???
Pls send pm
Anyone have good directions on how to program DACT Primary/Secondary phone numbers and Monitoring account numbers?
Pls send pm
There is not a universal 4100U/ES programmer. They are separate software sets. There are several versions of each programmer. The different versions matche a specific panel operating system version. All of the programmers require a software key (dongle) be connected to the computer to run.
Even if i sent you the programmers, without a dongle or software license you won’t be able to make changes to a config. All that you will be able to do is extract and send configurations/bin files of the panel. Something that you can do though is guess the passwords from the extracted config file…
