I made the following equation for bypass the signals from the 4100ES fire panel, but the equation is not working at all. I have assigned a user pseudo point P515 also assign a push switches and LED from panel display, TOF used for push switch and ON used for LED.
Simplex Custom Program
[INPUTS]
STATUS ON
P515 | DIGITAL | UTILITY | SIGNAL BYPASS
[END INPUTS]
[OUTPUTS]
TRACK ON PRI=9,9
P110 | DIGITAL | TROUBLE | AUDIO OVERRIDE TROUBLE
[END OUTPUTS]
If this is an audio system with speakers instead of horns and is running in default general alarm that should work for the speakers. It does not effect strobes. If there is custom audio programming, like fire floor, floor above, floor below more programming has to be done.
If the system is using standard horn/strobes that will have no effect.
#Retired STR-SG# Thanks for your response. You are right, I made that equation for standard horn/strobes signal bypass. Please, can you tell me the procedure for making a signal bypass for the standard horn/strobe? (Using Truealert ES appliances with the EPS+)
OK, that helps. I will have to do just a little research.
Is this a plain general system or is there some special signaling programmed?
PM sent.
