General Questions
Forum rules
(Rule #8)
(Rule #8)
- Jack
- Moderator
- YouTube Username: FireAlarmCollector
- Contact:
So, there's a security system installed in my house and it has been inactive since we moved in. I have some questions about it and I may use it.
So here we go:
-Will the system work if it's not hooked up to a monitoring center?
-Can I reset the factory A*T panel?
-Will it send a signal if someone were to hit an emergency button?
-Should it be wired into our household smoke detectors?
-If so, can I wire my home system into it?
Thanks.
So here we go:
Thanks.
Jack Kirkpatrick - Moderator
Reseller, Collector
ShopFireAlarms Website
FireAlarmCollector Site
FireAlarmCollector Youtube
Reseller, Collector
- NewAgeServer
- Administrator
- YouTube Username: NewAgeServerAlarm
- Contact:
Under most cases yes it will still work. If it was installed by A*T then they mostly likely dialed in to it and deleted the monitoring settings after your alarm monitoring contract was terminated. I have heard of A*T deleting the system programming as well rendering your panel blank so that it is totally useless without an A*T monitoring account. Best thing you can do is plug it in and find out.mytechtime wrote: -Will the system work if it's not hooked up to a monitoring center?
If it was installed by A*T and is a wired system, it is most likely a Honeywell Vista. A*T has an installer code they commonly used -- it should work to get into the system programming. Then you can default it from there.mytechtime wrote: -Can I reset the factory Unnamed Security Company panel?
If there's no monitoring account set up and the phone lines are hooked up, nothing would happen since the dial information was deleted from the programming upon monitoring account termination.mytechtime wrote: -Will it send a signal if someone were to hit an emergency button?
I do not think it is completely legal to wire 120V residential smokes into a BACP with an accessory relay. I know it is legal on fire alarm systems as long as it is set up to do a supervisory and not a full fire alarm.mytechtime wrote: -Should it be wired into our household smoke detectors?
If it were legal you'd need an accessory relay from your smoke detector manufacturer in order to do it.mytechtime wrote: -If so, can I wire my home system into it?
You're welcome. Check your PMs, I sent you a message.mytechtime wrote: Thanks.
Andrew Davis -- Chief Administrator & Site Owner
The Fire Panel & The Fire Panel Forums
All questions or concerns, please PM here or email at newageserver@thefirepanel.com
My Fire Alarm Site
YouTube Channel
My Fire Alarm Site
YouTube Channel
- Jack
- Moderator
- Contact:
Here is the main keypad for the system:
I can get pictures of the panel tomorrow.Jack Kirkpatrick - Moderator
Reseller, Collector
Reseller, Collector
- Jack
- Moderator
- Contact:
There's also this weird smoke detector in my house:
I'm pretty sure it's for the system too.Jack Kirkpatrick - Moderator
Reseller, Collector
Reseller, Collector
- NewAgeServer
- Administrator
- Contact:
Oh, well then no.
For whatever reason, A*T put in a DSC PowerSeries system, probably a PC1832.
You've got a rarer A*T installation since they almost always use Honeywell Vista.
They also put in a fixed english keypad, not an alpha keypad, which means re-programming one of these things is going to be VERY difficult. What "fixed english" means is that there's words that "light up" on the display kinda like LEDs for different system events. Here's an example of an Ademco 6150, a fixed english keypad.
Programming a system with a fixed english keypad is really hard because you have to know what all the little words mean when you're programming.
You can still test to see if you can get in though.
If you do *8 and then enter the installer code I PM'ed you, it will beep once if correct. Then press # to exit.
If it does not accept the installer code I PM'ed you, it will beep three times then make a really long beep.
These panels do have a backdoor, but unfortunately that backdoor can be disabled in programming. It's unlikely that A*T disabled the backdoor, however.
That smoke detector is a System Sensor 2100AT, which is a variant on the 2100 smoke detectors like the kind I used in my basement in System Test 26--29. It's a 4 wire detector and can run on either 12 or 24 volts, and it has a rate of rise heat detector and a piezo sounder that does Code 3.
I see you have a yellowed like crazy Kidde smoke next to it, should think about replacing that sometime.
My Fire Alarm Site
YouTube Channel
My Fire Alarm Site
YouTube Channel
- Jack
- Moderator
- Contact:
Yeah, that's something my dad doesn't think is needed... (one reason for installing my system)
It's about 13 years old.
Also if the code does not work, I may consider replacing the whole panel and keypad with something like a Concord 4 or a Vista if I can find one for cheap. Will that connect to the existing devices?
Reseller, Collector
Reseller, Collector
- Jack
- Moderator
- Contact:
OK, I tried it. It beeps rapidly 6 times and displays the armed lock thing on the side and a hand touching a keypad on the screen.
Reseller, Collector
Reseller, Collector
- NewAgeServer
- Administrator
- Contact:
Hot # to get out of there and don't try programming until you know what to do.
My Fire Alarm Site
YouTube Channel
My Fire Alarm Site
YouTube Channel
- Magnum Alert
- Retired Staff
- Contact:
If the armed light is on and the program light is flashing, you're in dealer program mode. Press # to exit now.
Do not try to do anything in dealer programming yet. You have a DSC Powerseries panel. It's probably the pc1864, their largest one in the series. Look on the green sticker on the board. You'll also need to know the panel firmware version. 4.2, 4.6, etc.
Do not try to program it until you have read and understand the manual. I can hook you up with the dsc manual if you give me the panel type and version.
Since this is A*T branded, there is no software access with DLS. do NOT get yourself locked out of programming!
Service Technician
Specializing in Ademco/First Alert, Napco, GE NetworX, DSC, DMP, and Moose.
- Jack
- Moderator
- Contact:
OK. I got out of there, and I tried a different code that worked. It returned to the normal screen.
Here are pictures of the panel: Maybe I should worry, it sounded like the battery was squealing.
I'm going to go get a closer look at the firmware.
Looks like A*T did a crappy job. There's no lock and I have not touched the wiring.
It's a powerseries 1616
Reseller, Collector
Reseller, Collector
- Magnum Alert
- Retired Staff
- Contact:
Just to clarify: Installations like this are not a result of "Big Blue" directly. There are "Authorized A*T Dealers" that are basically small independent companies who sell and install systems monitored by Big Blue. Tyco Fire and Security spun off their A*T and their security now is Tyco Integrated Security. Because of this dealership program, there is no "standard" panel type for A*T. The Safewatch panels are old Moose panels, or Vista-20SE or 20P systems. The PremisePro systems (around here) are DSC PC5020 or PC1864 systems. There are also GE Concord panels in some areas, EST fire alarm systems, Fire-Lite fire systems. It's whatever that particular dealer chose to sell and use. So, your sloppy panel is not Big Blue's fault, it's the result of a "dealer". Much like GM Corporation as a whole, and the individual Chevy dealer in your town.
DSC panels don't come with can locks, they actually cost extra. So it's standard practice to see one screwed shut.
One thing that is common with A*T is their characteristic 22/4 solid quad cable (like old telephone wire) with a blue conductor instead of the green conductor. In most cases, when a "takeover" is sold that includes a panel and keypad swap, there is seldom enough time to make the panel neat. I rip panels out and don't always have time to label and organize the wires. I wish I could, and I do what I can, but it's not always feasible.
Service Technician
- NewAgeServer
- Administrator
- Contact:
I added the word censor a while back because a lot of the members on this forum bash A*T and I did not want the posts where we make fun of A*T showing up in search engine results when search engine bots crawl the site.
My Fire Alarm Site
YouTube Channel
My Fire Alarm Site
YouTube Channel
- nightfly287
- Wiki Team Member
It has to do with the forum's liability. Searching for A*T (without the censor, of course) would not bring up any search results from The Fire Panel. Since A*T is proprietary, people asking questions on this forum won't be tied to the search term, reducing the possibility of TFP getting in trouble.Prog wrote:[offtopic]Why is Unnamed Security Company censored? It's causing lots of confusion, at least for me. [/offtopic]
Try it yourself:
Searching for A*T [without censor] in TFP's domain
Searching for "Unknown Security Company" in TFP's domain
No backdoor instructions there!
EDIT: Andrew, you beat me to it.
nightfly287 -- Director of Sarcasm
- Jack
- Moderator
- Contact:
Would the installer code be able to arm/disarm the system?
If not, how could I change the user code?
Reseller, Collector
Reseller, Collector
