4098-9601 R & R
4004 2 wire series connect. System active can smoke detector be removed and another installed without alarming system or do I need to shut down zone, notify monitor company.
ALWAYS put system on test with monitoring before working on it! The one time you don’t the fire department will be at your door.
The system should just go into trouble while the head is out. But sometimes unexpected things happen.
