Not sure if anyone will know this, as it came up once a LONG time ago, but does anyone know of a way to adjust the strobe flash speed on the 7002T? I thought I recall someone once saying there’s a (hex)screw on the back of it that will adjust the strobe speed, but I’m not sure who said it. You’d think there’d be some way, since they all flash at a different speed.
I recall being able to change the flash speed and horn pitch by tightening/loosening the bolt that goes through the gray cardboard thing. There should also be a potentiometer on the strobe board itself like the WST-series ones, but I’ve never removed one from a 7002T to find out.
7002T’s will shock you even if they aren’t operating! The strobe capacitor holds such a big charge that if you were to touch a finger to each power terminal on the alarm, every part of your hand that the electricity flowed through would hurt and go numb for a little while. Discharge the strobe by shorting the power leads to the alarm before messing with anything. You might get a healthy spark.
That happened to me when I removed my 7002T strobe assembly, almost a week after applying power! Except I touched the circuit board instead, probably near the power leads.
As for the OP, I don’t recall seeing any potentiometers.
I had a 110 candela RSS strobe bite me once… It made my finger numb for hours. If you know what a 1 candela strobe capacitor shock feels like then imagine that 110x more painful.
Back to the OP, IIRC there’s a volume screw or something. When loosened the horn moves further and that lowers the pitch and makes the strobe slower.
Don’t quote me, I’m not so sure.
