I have a AT focus 200p panel and am able to get into most of the programming. I can change the groups and points and so on. The one thing that I can’t find is were you can change the default home screen message. The text that is above the focus 200p when the system is armed and normal. Is there a way to change this? Would it be in the hex decimal Programing or am I going over a step. Thanks. If anyone works or has worked with AT and has a hex decimal sheet that would be greatly appreciated. Thanks.
          Whoa Wait… you’ve got a Focus and you can program it?
You sir, have something very rare because almost always these things are locked and can’t be programmed.
Yeah. We take a lot of them out and replace with DMP, and yeah they are mostly locked out. This one and a couple others suprising you can change the Programing for the most part like the ID codes, groups/points, relays and communications. But stuff like the home screen and other features I couldn’t get into.
I used to work them, I don’t remember if it can be changed in hex data or not. I always had data change it for me. I was always cautioned “if you don’t know what you’re doing, you are better off staying out of hex programming “ bad things happen
