B200S-WH - Do I need a control module?
Do I need to use a CMF-300 control module with the B200S-WH sounder base, or can the auxiliary power be connected directly to the base without the module? Can I use the NAC? Will the base know when to turn on (i have it all programmed correct in FS-TOOLS) I just want to make sure I need a module or not for it to work correctly (so if i connect it to a nac it won’t alarm) - Also I am not using the base for FA. I will have a SD365CO head on it and have it activate only if CO is detected.
many thanks
-NW
