This weekend I went to Janesville, WI because my sister from Ohio came up there for a visit. Sadly it didn’t turn out as expected, as my brother is having marital problems, I’ll leave it at that. Anyways, we stayed at the Baymont Inn. I was there a couple of years ago, and to recap, here’s the FAs
4002 Panel
4904-9501 strobe in restroom (almost like mine, mine has the reflector).
The alarms are either
9840s on 4903-9501 plates w/ 4904-9105 strobes
or 4901-9805s on same plates. This one’s in the pool, I saw another in a stairway.
The smokes are
2908-9201 heads on 2098-9211 bases, although I could have sworn I saw a 2098-9536-style base, but if it was a -9536 that’d be incompatible on the same circuit (I think) since the -9211s are 2-wire and the -9536s are 4. Plus the online 4002 manual doesn’t show any 4-wire diagrams, except the “Style D Initiating Device Circuit” which is basically an alternate 2-wire setup, while the 2098 base manual showed that the 2098-9536 was compatible with the 4002 in a diagram. It might have been wrongly worded. Is there a 2-wire base that looks like a 2098-9536 (or a “beauty cover” for the -9211?) Anyways,
The pulls are 2099s.
These pics were taken back in '08.
Then we came back, and went to our friends in Lake City. On our way we stopped at Green Mill Restaurant and Bar in Winona. It was hooked to The Plaza Hotel & Suites. The restaurant had a 4005 panel with NSs and RSSs in the restrooms, and 2099 Pulls. Didn’t see any smokes, and didn’t go into the hotel itself, I’m assuming the hotel has its own system and the restaurant’s 4005 might or might not be connected to it.
