We had this on the old board, but I want to bring it up again. How many of you have ever come across a bad installation job. I don’t mean one with one or two minor flaws, I mean a bad job in general.
Here’s one that applies to me. A bowling alley in my area had an “upgrade” a little more than a year ago. I went there in February of 2006 to a rock-n-bowl, and these were the alarms then:
Simplex 2901-9833s on the 2903 light plate. How do I know it was a light? Because that same evening they accidentally set the alarm off because of all the fog from the fog machines (tripped the detectors). The system then was a 4001 (newer version, because the door was black - I saw it), and the pulls were the 4251-20 T-Bars. Now, when the alarm went off, it was basically inaudible because there was no alarm where I was. The bowling alley building is uniquely shaped - it consists of 2 rectangles, one straignt, one tipped at a 45 degree angle. The exits were on the corners of the rectangle turned 45 degrees. The alarms are all located at the exits, however, in one corner, there’s a snackbar, and for some reason, there’s no alarm in that corner. That was the corner where I was when the alarm went off, so again, it was barely audible. I think there was no alarm because that corner looked to be recently rennovated, and instead of replacing the alarm, they just got rid of it. But that’s not the bad job I’m talking about. Fast forward to June 2006, and I went there again to bowl. I was excieted about going because I wanted to get a picture of the alarms (the one you see above is a pic from an eBay auction). Well, when I got there, I got more than I bargained for. THIS is what they looked like 4 months later:
How bad can an install job possibly get? They just slapped SpectrAlerts on where the -9833s used to be, and as you can see from the first pic, it doesn’t quite fit. The 4001 is now gone, in favor of a Honeywell keypad and extension panel. IDK if the pulls still work, but I assume they do, and they just disconnected the old signals and and hooked the exitsting wires upto the SpectrAlerts. Also, I went back a couple of weeks ago, and nothing’s changed. This time, I went back to that corner where there was no alarm to see if they installed a SpectrAlert there, and there’s still nothing there, at least from what I could see, and I did check quite well. This is perhaps the cheapest and poorly done upgrades I’ve seen…
Has anyone else seen similiar install jobs? I’m sure the techs have a few stories up their sleves…
