Me and my husband recently started focusing more on improving safety around our home, and one thing we realized we probably shouldn’t ignore is getting a good smoke and carbon monoxide detector.
Since we’re both complete beginners when it comes to home safety devices, we’ve been trying to figure out what actually makes the best smoke and carbon monoxide detector for everyday home use—especially something reliable, easy to install, and not constantly giving false alarms.
We’ve done some research and shortlisted a few models that keep coming up, but now we’re a bit confused about which one would be the right fit for us:
Battery-powered models are easier to install
Hardwired models seem more reliable long term
Smart detectors offer phone alerts and extra features
Some detectors are more sensitive and may cause false alarms near kitchens
Still, it’s hard to know what really matters when you actually start using one day-to-day.
We’d really appreciate advice from people who have experience:
Which smoke and carbon monoxide detector do you use at home?
Is it reliable and easy to maintain?
Did you notice any issues after a few months?
If you had to choose again, would you go with the same one?
We’re just trying to make a smart decision and avoid wasting money on the wrong option. Any honest feedback would really help us out
I would say, a first alert smoke/carbon dioxide detector works good in this situation, since a couple months ago they replaced my homes smoke alarm’s and they work very well, and hardwired detectors are a little harder for a first timer, so its better to go easier with a battery detector.
Most fire codes prohibit the use of battery-only smoke alarms in locations where hardwired smoke alarms were previously installed. If you are installing smoke alarms in locations that previously did not have them or replacing existing battery-only smoke alarms, then battery-only smoke alarms might be permitted, but in that case, many jurisdictions require the smoke alarm to have a sealed 10 year battery.
I definitely recommend alarms from first alert and gentex, please stay away from Kidde recently there alarms have drop in quality.
First alerts lower end alarms may be a little bit hit or miss: SMICO100-AC (hardwired), SMCO100V-AC (hardwired), SMCO500V (wireless) or SMCO200 (battery).
Gentex is the best but on average is more expensive: SC series (hardwired).
X-sense I’ve haven’t heard of any problems with: XP02-AR (hardwired), XP0A-SR (battery), SC06 (battery), SC06-W (wireless) or SC01-W (wireless).
You can only replace hardwired smoke alarms with other hardwired alarms due to modern building codes, if it’s battery you can replace it with anything. I excluded anything with advanced features like a base station or smart/wifi, but those are going to be more expensive and most of the time you don’t need them.
Above anything avoid alarms that are not UL listed or don’t have legitimate company behind them, These are usually on E-bay or Amazon and are typically completely junk.
I agree with most of what the others have said, though I’ll add a couple things: #1: Do not go with ionization-only detectors, as they are the least-reliable in most kinds of home fires: either go with combination ionization-photoelectric (though most of the time these kinds of detectors don’t also have a CO sensor) or photoelectric-only. #2: I would not trust anything from X-Sense or China in general given how many things from the latter are very cheaply-made quality-wise, & with life safety you can’t risk having a device fail just to save money: BRK/First Alert & Gentex are indeed excellent though as they’ve been in the life safety business for many years & definitely know how to make a smoke detector! (not Kidde though as has been said here already, not anymore at least: they might have made good-quality products at one time, but that era is long over)
Correct, I don’t know if the house has hardwired smoke alarms, but I don’t think I have ever seen a manufacturer explain that their battery-only smoke alarms are not permitted to replace hardwired smoke alarms, which is why I pointed that out.
Personally, First Alert is the only company I trust for residential smoke alarms. These are life safety devices, meant to keep you alive in the event of an emergency. I personally installed the First Alert SMCO100V-AC alarms in my home after the Siterwell versions put in by our builder malfunctioned. Kidde has had plenty of recalls over the years, and companies like X-Sense are too new to make me comfortable.
Recently, X-Sense alarms were pulled off Amazon (they are since back) because they did not have up to date UL217 testing. They were tested with an older version only at the time. The thing is that the requirement was clear for a while before the listings were pulled. A company worth it’s salt should be trying to ensure they are compliant with latest UL standards as soon as possible, and X-Sense failed to do that. While I’m happy they have corrected the matter, it shouldn’t have been an issue in the first place.
It’s been a few months since I started this thread, so I wanted to come back and share an update.
Over the past several months, I spent more time comparing different smoke and carbon monoxide detectors, reading long-term owner reviews, checking expert recommendations, and learning what features actually matter in everyday use. My perspective has definitely changed after doing more research.
For homeowners looking for a reliable combination smoke and CO detector, these are the models that stood out the most:
First Alert Smoke & Carbon Monoxide Detector
Kidde Smoke & Carbon Monoxide Detector
X-Sense Combination Detector
Google Nest Protect (great if you want smart features)
First Alert Onelink Safe & Sound (premium option)
One thing I realized is that the best detector isn’t just about having the most features. Reliability, ease of installation, battery life, maintenance, and minimizing false alarms are just as important. Whether you choose a battery-powered, hardwired, or smart model really depends on your home’s setup and your budget.
Thanks to everyone who shared their experiences on this thread. Your advice helped me understand what to look for and made choosing much easier.
I also put together an updated comparison covering the features, pros and cons, and what I learned after researching these detectors. If anyone is interested, here’s the link:
As I already said before, I would not trust anything from X-Sense or Kidde (or China in general in the case of the former), & neither the Nest Protect nor the First Alert Onelink Safe & Sound are made anymore (thank God the former isn’t if you ask me, as many videos have shown that, as one might expect for a so-called “smart” device, it was nothing but a buggy piece of junk that would frequently false alarm (what a surprise for a company only interested in making “smart” products & with no prior experience in the life safety industry honestly, the latter in stark contrast to BRK/First Alert & Gentex, both of whom, as said, have many decades of experience in said industry under their belts).
Is there a reason the Gentex PLACE isn’t even on your list to consider? (Yes, it is a bit expensive, and not available through every last retail outlet on the sun. It’s also the only smoke alarm that can do low frequency notification at this point in time, and has better interconnect support than all the other “smart” alarms I’ve seen so far.)
Is the PLACE compatible with standard home integration systems like Matter? The internet seems to suggest that it is not, which might be the reason for preferring First Alert.
