Found this, does this mean I can use a notifier call point on my 3030?
pretty sure the european notifier panels use a different protocol so i’d assume not.
Notifier call points are just rebranded KAC call points
Most conventional call points should be compatible with most conventional panels as like pull stations they’re just a fancy switch.
yes they can work. i had a bgx work on a euro panel so i assume it works the other way. The older ones run on clip and the newer ones run opal and clip but opal is our name for flashscan. it will most likely work
Also, in the middle east i have seen call points that are used in europe (not the asian model with the same design) running on clip and flashscan on a 3030
