Communicator installation
Hello all. I am new to fire alarms and trying to learn. I have been tasked with installing a dialer on a notifier nfs 320. I am struggling to find where to connect the communicator to the panel as far when it goes into alarm. Is anyone able to help? greatly appreciated
Are you installing a Notifier udact or udact-2 or is this a stand alone dialer youre looking to put up alarm, Trouble, supervisory contacts only?
its a 411ud comunicator transmitter which is 4 channel. 1st channel will be a fire alarm activation, 2nd will be a trouble activation, and 3rd will be a supervisory alarm. thanks for the response
The contacts on 320 you will wire to are on the bottom left corner of the board. There are 2 quick connect plugs on the corner of the board you can remove and wire.
