Edwards "Adaptahorn" Model 364!
Found these inactive horns in Cadillac High School’s annex building. There are addressable TrueAlerts in the hallways along side them now so I can only assume the panel is a 4010 of some sort. I’m not sure if the TrueAlerts replaced the Adaptahorns or not.
I have one that’s exactly the same as that, only mine is 10VAC (though I’m assuming that that’s basically the same as 12VAC).
You ought to see if you can get those if they’re ever removed.
I’m going to try emailing the school about them eventually. I will for sure make an update if I can get them.
Update: I found the only other one in the structure which means there are only two of them.
That one appears to have had its “FIRE HORN” label removed at some point given the screwholes for it.
It looks like it broke and fell off. The screws appeared to still be there. Who knows what kind of vandalism these things have experienced over the years.
Update: I emailed the school and unfortunately never heard back. I have another contact I might try but there’s a slim chance anything will happen.
