Edward's pull station with no key insert.
There is an Edward’s pull station that has no key insert. How does it get reset?
Probably with a hex wrench or screwdriver. For example, the 270-SPO, which has no key lock. gets reset by opening the station with a screw driver. If you watch http://youtu.be/d7pZD31sEzw this video, you can see how it gets reset.
A photo would help…
It depends on what model the Edwards pull station is, do you know the model # er the name of the pull?
Hence why I asked for a photo…
The one pictured here is a 270-SPO and only comes in a screwdriver reset version.
The newer 278B-1110 is the screw reset version of it’s “brother”, the 278B-1120 / SIGA-278.
You can see the screw on the top, in the center.
